1994 Jeep Grand Cherokee Laredo - All windows stopped working! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1994 Jeep Grand Cherokee Laredo - All windows stopped working!
Rough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 09-06-2006, 04:09 PM   #1
BrentNewland
I have a 1994 Jeep Grand Cherokee Laredo with the 5.7 V8. The other day, I turned off the car, locked the doors, and went inside the store. I came outside, unlocked the car, turned it on, and immediately tried rolling down the window. Nothing happened. Okay, so I tried the other windows. Nothing. I tried the switches on the other doors, still nothing. The power locks and lock switches still work. I checked the fuse with a multimeter and it does carry current. I pulled the switch on the driver's door and tested it, it appears to work fine (with a multimeter). I checked all the fuses under the hood, and they're all good. What could the problem be?
BrentNewland is offline   Reply With Quote
Unread 09-06-2006, 08:23 PM   #2
stmprnch
Any answers out there?
I'm hoping that someone with the "Secret Electric Window Decoder Ring" responds to this one so I can solve the problem with my '93 ZJ. I'm done pulling my hair out until I hear or see something that sounds like a reasonable next test. With mine the drivers rear window stopped going up, it goes down just fine. Now for those of you that aren't aware, we get about 100 inches of rain in Northwest Oregon. Windows that don't roll up are a bit of a problem.
Ron
stmprnch is offline   Reply With Quote
Unread 09-07-2006, 04:24 AM   #3
SnaFu2
According to the FSM grounds seem to be the likely cause of ur problem.
U can get a copy of the FSM on NAGCA site.
Someone posted a link to the 93-98 FSMs plus FSM for wrangler and one for the liberty.
Here is the link to the FSMs http://www.jeepmania.com/Manuels NAGCA also has on their site the '98 and '01
FSMs.
SnaFu2 is offline   Reply With Quote
Unread 09-07-2006, 07:47 AM   #4
greasefingers
1994 ZJ
Since the all stopped working at once, then it can usually be narrowed to the power or ground wire to the master switch on the drivers’ door. That is where I would start.
The wires that go from the body to the door (inside that rubber accordion type booty) is usually where the wire (s) break due to mechanical flexing.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 09-07-2006, 12:57 PM   #5
Dr. Righteous
1994 ZJ
Power windows, door locks, mirrors, ect are usually the wiring harness in the rubber boot on the driver door. Pull that rubber boot back and look for broken wires. Both my ZJ had this problem.
Turbocharge it!
Then I'm interested!
'94 ZJ Limited Lifted and LOCKED!
'04 Durango Limited (the wife mobile)
'72 Plymouth Satellite Sebring Plus (Resto MoPar)
Dr. Righteous is offline   Reply With Quote
Unread 09-07-2006, 01:27 PM   #6
RFisher
Voltage
I know you checked the switch, but did you check to see if there is voltage at the switch? If ground is a problem, try using a temporary jumper to chasis ground to see if that fixes it.
RFisher is offline   Reply With Quote
Unread 09-08-2006, 03:33 AM   #7
BrentNewland
I pulled back the boot, and I guess the previous owner had thsi problem, because there was already a butt-end connector on the ground to the window switch. I replaced it (looks like the wire broke from too much movement) and it works fine. Thanks guys!
