1994 jeep grand cherokee i need help, please advise! - JeepForum.com
post #1 of 12 Old 10-27-2011, 02:06 PM Thread Starter
lvngtheJEEPlife
i am having a few problems with my jeep recently..
-my motor seem to be going thru oil alot, its blowing out the crankcase breather, which i thought was normalbut it seems a little excessive..
-also my trans seems to be havin issues,which i think could just be a presure line?.. but it is shifting into third gear almost immediatly from 2nd just when im starting out though, it just seems a little gummy rest of the time, so any ideasor should i take it in?
-last thing, i was on the highway doing about 75, (the fastest ivegone consistently) and it started shaking violently out of no where, i pulled off expecting a flat but could find nothing wrong.. so i got back on and did 70.. no problem. any idea what that would be? misfire maybe?
lvngtheJEEPlife is offline
post #2 of 12 Old 10-27-2011, 02:28 PM
melk
V8 or inline-6?
No it's not normal, your PCV is likely clogged. Plan on buying new elbows and grommets. Not much $ at all.
Trans, start with fresh fluid and filter. If you want to really go after it, swap out the gov pressure sensor and solenoid, about $80-100. It's easily done while you have the filter off.
3rd issue is death wobble, which can have many different causes. Not likely a misfire but see if there are any codes stored.
melk is offline
post #3 of 12 Old 10-27-2011, 08:41 PM
JS97ZJ
Fumes from the valve cover and oil consumption could also be an indication of bad valve guides. Do a compression test.
Check your tires for wear, they will usually hop at 75-80 when their nearing the end of their life.
JS97ZJ is offline
post #4 of 12 Old 10-27-2011, 09:50 PM Thread Starter
lvngtheJEEPlife
ok thanks guys!
-it is the straight 6
-the tires are quiet worn in the front, i replaced the rear one though because the matching ones from the front were dry rotted and completly worn out.
-so should i just drop the trans pan? cuz i dont have a drain plug..
post #5 of 12 Old 10-27-2011, 10:12 PM
JS97ZJ
The trans, TC, and differential fluids all need to be replaced every 35k. No transmissions don't have drain plugs because the filters are internal and the bands should be adjusted at every fluid change.
JS97ZJ is offline
post #6 of 12 Old 10-27-2011, 10:36 PM Thread Starter
lvngtheJEEPlife
ok well i dont know if it has ever been done, i already did the TC and DIFS, even though it has never been done i should still do it right?
post #7 of 12 Old 10-27-2011, 11:24 PM
Virmagicus
Virmagicus's Avatar
Get about 5-6 quarts of ATF+4,filter,and one of those big oil catch pans. Measure how much fluid comes out & add the same amount back in. Depending on the fluid condition you may have to do this a few times in short intervals. Get a white piece of paper towel and inspect the color of the fluid. It should be red, a dark color is not good.
Jeff
Virmagicus is offline
post #8 of 12 Old 10-27-2011, 11:26 PM Thread Starter
lvngtheJEEPlife
ok cool thanks, well when i bought it, they had about twice the amount of fluid needed in there..like inches above the max full mark. so i drained some but its still over full. thanks for all the help though! it was very much needed.
post #9 of 12 Old 10-27-2011, 11:28 PM
Virmagicus
Virmagicus's Avatar
Make sure you check the level in neutral & running when the fluid just gets hot. Drive around for about 15 minutes. Sounds like you checked it in park...hence the high level.
Jeff
post #10 of 12 Old 10-27-2011, 11:53 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Sounds like you're checking it while off and in park. Your are now running low on fluid causing the trans problems.it's also probably done damage by now.
What transfer case do you have? Only the selec-trac can cope with unevenly worn tires.
ratmonkey is offline
post #11 of 12 Old 10-28-2011, 12:10 AM Thread Starter
lvngtheJEEPlife
yeah ive tried both ways.. and i took out a few quarts and checked a few times each way again and was still high.. weird. ill drain it and use all the advice though. thanks alot guys!
post #12 of 12 Old 11-10-2011, 01:53 PM
tcar
Is it a GRAND Cherokee that you're talking about? Your signature says XJ, which is a Cherokee... totally different vehicle than we're talking about here.
But, the answers above would still be valid.
Be sure you check in NEUTRAL, not PARK... common mistake.
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
1994 jeep grand cherokee laredo v8 Help!!! grandcheves ZJ Grand Cherokee Forum 12 02-17-2014 10:51 PM
My 1994 jeep grand cherokee pics turnerjc03 ZJ Grand Cherokee Forum 17 07-10-2008 06:23 PM
having trouble with 1994 jeep grand cherokee rgrocks ZJ Grand Cherokee Forum 3 04-18-2008 08:48 AM
1994 Jeep Grand Cherokee bohawg ZJ Grand Cherokee Forum 5 03-30-2008 03:32 PM
1994 Jeep Grand Cherokee jasoncam ZJ Grand Cherokee Forum 0 07-15-2002 06:30 AM
