Quantcast 1994 Jeep Grand Cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 1994 Jeep Grand Cherokee
Old 12-13-2007, 09:41 PM   #1
bohawg
Yes im hoping someone can help me. I have a 42 Re transmission and its not going into overdrive. I took it to a transmission shop and we hooked it up to a comuputer and took it for a ride. He said the governor sensoer was down on the readings and told me to replace the governor pressure sensor and solonoid which i did. It did not take care of the problem, i did get it to go into overdrive twice tonight but that was it. Seems likes its doing it when its cold but not hot. I have replaced the motor recently and now working on this. My temp, reading is reading good on motor so really im not sure what its doing. My push button on overdrive seems to be working ok the light comes on and off when i push on it. One other thing the transmission was rebuilt couple years ago is what i was told by previous owners. THe motor was blown when i got it so i was not sure how it was running before hand with transmission. Does anyone know what this might be? could it be a ground somewhere. There is no noise or nothing coming from transmission and when it goes into overdrive it goes it good but only does maybe once and thats it. THanks any comments would be appreciated
bohawg is offline   Reply With Quote
Old 12-13-2007, 10:18 PM   #2
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
This is a simple question? Have you checked the fluid level? Sometimes when the transmissions are just a bit low, that act very wacky. So, check the fluid? Have you checked the transmission pan (after draining) to see if there are metal flakes?
It could also be a bad shift cable.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 12-13-2007, 10:29 PM   #3
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Was it the overdrive solenoid or the governor solenoid you replaced? Could be a ground problem, as you said.
You have a PM.
-Steve
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline   Reply With Quote
Old 12-20-2007, 10:31 PM   #4
bohawg
i just replaced the governor solenoid does the 42re have a overdrive solenoid , never read anything that it had a overdrive solenoid
Old 12-29-2007, 01:17 AM   #5
SJZ
SJZ's Avatar
Sorry, I don't have any personal experience with it, but according to the manual it does.
-Steve
Old 03-30-2008, 04:32 PM   #6
2LMAKER
Did you resolve this issue?
I have 94 ZJ limited with 4.0L and having same problem.
Thanks
2LMAKER is offline   Reply With Quote
Glock Forum
