1994 5.2 oil dipstick problem - JeepForum.com
post #1 of 14 Old 07-01-2011, 07:21 PM Thread Starter
Shpuker
1994 ZJ
Took the Oil dipstick out to check the oil the other day, and it doesn't wanna go back in (its always had problems with sliding back in but its always actually gone in, wont this time). Makes a sound like its hitting something metal though, and it goes down the tube into the engine (about 3 inches in) before it hits anything.
Any one have any tips here?
Shpuker is offline
post #2 of 14 Old 07-01-2011, 08:53 PM
ZeeJay1997
Sounds like it may be the wrong dipstick. Maybe someone will go check theirs and post the number.
I'll state the obvious here...The tip of the dipstick usually is suspended in the oil pan.
ZeeJay1997 is offline
post #3 of 14 Old 07-02-2011, 06:00 AM
Derph
1994 ZJ
Don't put it in sideways. (thats what she said!)
Derph is offline
post #4 of 14 Old 07-04-2011, 12:00 PM Thread Starter
Shpuker
1994 ZJ
Could be I supose, it went in better when it was newer and just got progressively worse now it wont.
Shpuker is offline
post #5 of 14 Old 07-04-2011, 03:06 PM
JrMechanic
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #6 of 14 Old 07-04-2011, 03:30 PM
Obie95Sahara
Originally Posted by JrMechanic View Post
The speedometer isn't controlled by the output speed sensor, it's run by the speed sensor on the transfer case.
That's great info... Just not sure what it has to do with an oil dipstick though
Obie95Sahara is offline
post #7 of 14 Old 07-04-2011, 03:31 PM
sebian
Good advise, but probably not related to a oil dipstick.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #8 of 14 Old 07-04-2011, 04:20 PM
johnridesjeeps
YES! Best answer.
But seriously. If every things running good X2 on wrong dipstick or your puttin it in sideways.
johnridesjeeps is offline
post #9 of 14 Old 07-04-2011, 05:12 PM
JrMechanic
Sorry, somehow posted in the wrong thread.
post #10 of 14 Old 07-04-2011, 11:31 PM Thread Starter
Shpuker
1994 ZJ
Originally Posted by johnridesjeeps View Post
YES! Best answer.
Puttin it in like always, tried every angle, checked if it was bent wrong, everything, it just catches on something about 3 ish inches into past the visible end of the tube, so I dunno if somethings not lining up correctly or what but its not quite right
Shpuker is offline
post #11 of 14 Old 07-05-2011, 10:57 AM
Derph
1994 ZJ
On you're next oil change pull the dipstick tube off and inspect it
Derph is offline
post #12 of 14 Old 07-07-2011, 11:39 AM
tcar
Rotate it in about 10 degree increments until it goes in.
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #13 of 14 Old 07-07-2011, 11:40 PM
PeriwinkleZJ
I actually have the exact same issue with mine, after I did my oil pan.
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD:
PeriwinkleZJ is offline
post #14 of 14 Old 07-13-2011, 01:40 AM Thread Starter
Shpuker
1994 ZJ
Yea its rather inconvenient ey? my guess is that its gotta be a problem with something not lining up correctly at the oil pan
Shpuker is offline
1994 gcl, charging problem, HELP PLEASE! ASAP Strangedayz17 ZJ Grand Cherokee Forum 4 01-10-2011 01:56 PM
1994 ZJ electrical problem nubnub11 ZJ Grand Cherokee Forum 4 01-04-2007 10:35 AM
Charging Problem 1994 ZJ Journeytojeep ZJ Grand Cherokee Forum 5 12-02-2006 08:29 AM
1994 ZJ Transmission Problem rubiconrebuild ZJ Grand Cherokee Forum 2 11-12-2006 07:55 PM
1994 GC Shifting Problem. Fixes?? ChaoticBastard ZJ Grand Cherokee Forum 4 08-14-2005 05:08 PM
