1993 Oil Filter Adapter seal kit is not #04720363. What is the correct seal kit ??? - JeepForum.com
post #1 of 3 Old 04-09-2008, 12:32 AM Thread Starter
Panchojeep
1993 Oil Filter Adapter seal kit is not #1-04720363. What is the correct seal kit ???
Re. 1993 Grand Cherokee, 4.0. I bought it new in May of 1992.
The dealer gave me a seal kit, part #1-04720363. Kit had 3 O-rings in it. Only one that seemed to fit was the largest ring. The other two smaller rings did not fit the bolt, or the flange on the bolt.
Does anyone know the correct part number for my vehicle ?
Panchojeep is offline
post #2 of 3 Old 04-10-2008, 06:22 PM
zjay
My dealer parts guy came up with 4720363, same thing. You were able to get the bolt out of the housing, right? It needs a good shove sometimes.
zjay is offline
post #3 of 3 Old 04-11-2008, 09:38 AM Thread Starter
Panchojeep
NAPA didn't have the O rings. Dealer had O rings as individual parts ($10.26).
Don't waste your time with any other O ring sets or parts numbers.
My ZJ is very early. Bought it new in May 1992, 30 days after the vehicle got to the dealership.
So, if your ZJ is among the very first manufactured, then, read on for the O ring solution.
Here's the answer: link and transcription.
Oil Filter Adapter O Rings for very, very early 1993 (purchased May 1992) Grand Cherokee ZJ with 5/8 inch bolt on adapter:
Link:
http://www.lunghd.com/Tech_Articles/...nt_O-Rings.htm
Transcription:
Note! There are a couple of different o-ring styles. HO engines have an o-ring 'kit' available w/ all three o-rings packaged together so in this regard... you're in luck! Just go to the dealer and ask for the "kit" with the o-rings together and you'll be ready to go. Getting the o-rings isn't much easier than that! The hard part will come when you start cussing that TORX bolt holding the filter mount on. Early / RENIX engines require that you buy all three o-rings seperately as they do NOT interchange with the HO o-rings. This is due to the different center bolt (TORX vs. hex head) that retains the filter mount. No big deal - they're a stock item for the dealer. These o-rings may be available at your local auto-parts store as well - they aren't anything special but you must have the correct sizes to prevent more leakage! Here are the dealer part numbers and sizes for the RENIX o-rings:
33002970 o-ring .799x.103
33002971 o-ring 1.296x.13
33002972 o-ring oil filter AD
WJ rear axle seal (no inner seal???) cmonson ZJ Grand Cherokee Forum 15 08-02-2009 10:50 AM
Trans Output Seal & TC input seal shop pricing graffix000 ZJ Grand Cherokee Forum 0 05-05-2009 01:35 PM
WJ rear axle seal (no inner seal???) cmonson ZJ Grand Cherokee Forum 0 04-28-2009 04:49 PM
Transmission Filter Seal will_b ZJ Grand Cherokee Forum 14 03-08-2007 09:46 AM
1993 JGC Oil Pan seal replacement WBowie ZJ Grand Cherokee Forum 9 04-20-2006 06:53 AM
