1993 jeep grand cherokee tranfer case code??? - JeepForum.com
post #1 of 10 Old 01-03-2013, 04:41 PM Thread Starter
93zjalta
i know there is probably a thread on this already but im in a bind and don't have time to go searching just need a quick answer.
im new to jeeps so i have no clue but my transfer case exploded today driving on the high way and i cant find the stamp with the code anywhere in the shrapnel. so if someone can give the code it would be greatly appreciated.
it is a 1993 jeep grand Cherokee Laredo.
Thanks!
93zjalta is offline
post #2 of 10 Old 01-03-2013, 04:58 PM
Uniblurb
Uniblurb's Avatar
There should be a red metal tag on the back/top of your transfer case which lists the model number. It also helps to post what size engine you have on your 93.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #3 of 10 Old 01-03-2013, 05:01 PM
fljeepney
NP 231-2wd,4 part time,4 lo
NP 242-2wd,4 part time,4 full time,4 lo
Np 249- 4 full time,4 lo
Look at your shifter bezel and see if one of the above corresponds with what you have.Of course all cases have neutral too.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
1985 Corolla AE86 coupe
fljeepney is offline
post #4 of 10 Old 01-03-2013, 06:12 PM
rcMikeS1990
1994 ZJ
Saw a bezel at jy today that said 4 all time , n, 4lo. Just throwing it out there
1994 Grand Cherokee Limited 5.2L V8 318, Spectre cold air intake, Flowmaster Super44 muffler to 3.5" resonator tip, 30x9.5 BFG A/T's, Custom Tranny and TC shifter mod
My Build Thread--not sure how to make that the link-http://www.jeepforum.com/forum/f13/my-build-thread-1568707/
rcMikeS1990 is offline
post #5 of 10 Old 01-03-2013, 06:19 PM
fljeepney
4 all time is 4 full time
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #6 of 10 Old 01-03-2013, 06:23 PM
dnuccio
IIRC on a 231 the bezel said 4hi not 4 part time
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 10 Old 01-03-2013, 07:02 PM
fljeepney
Sorry
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #8 of 10 Old 01-03-2013, 08:42 PM Thread Starter
93zjalta
its a straight 6 4.0l
93zjalta is offline
post #9 of 10 Old 01-03-2013, 10:02 PM
Uniblurb
Uniblurb's Avatar
Thanks, so have you figured out what transfer case you have by the info on the shifter bezel fljeepney and dnuccio posted above?
What exactly caused it to come apart? On my 242 the top rubber plug fell/blew out of the top which caused the fluid to blow out and I chewed it up before I even knew it. Installed a JY shelf unit after resealing, still wasn't all that cheap, but had about a 60-90 day warranty.
post #10 of 10 Old 01-03-2013, 11:07 PM
rcMikeS1990
1994 ZJ
gotcha, thats what I figured
transfer case , transfer case part , zj
