1993 Jeep Grand Cherokee Help - JeepForum.com
post #1 of 9 Old 04-20-2006, 10:26 PM Thread Starter
chuck444
I own the above mention vehicle and I am having a difficult time starting it. This is what happened…
I did not start the car for about three weeks.
Went to start it and the battery was dead.
Recharged the battery to what I thought was a good charge.
Tried to start it sounded like it wanted to turn over but would not.
If I am reading the engine codes right this is what I have…
---12 Battery or computer recently disconnected and
---55 End of codes
I replaced the battery, sounds like there is now enough power but will still not turn over and same codes come up.
Any advice as what to try to get this jeep started would be very appreciated.
chuck444 is offline
post #2 of 9 Old 04-20-2006, 10:35 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
You put a brand new battery in and it still won't turn over? Sounds like the starter to me.
Of course this is assuming that by turning over you mean it won't crank over like it used to.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #3 of 9 Old 04-20-2006, 11:11 PM
gunthagunth
gunthagunth's Avatar
yeah get a long pipe/crowbar down in the engine and bang that starter a bit giving it some good jolts. stay away from the wires you dont wanna break em. i had the same problem about a year ago. banged it around and no problems since. i still carry the crowbar for when it gives me trouble so i can beat it back in line
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #4 of 9 Old 04-20-2006, 11:13 PM
gunthagunth
also to verify that your battery connection is still good turn your headlights and interior light on and watch your interior light while you crank the engine, if the lights turn out you have a bad connection
post #5 of 9 Old 04-20-2006, 11:19 PM
Nick ZJ
Nick ZJ's Avatar
Im set on the starter or the starter coil. Same symptoms I had and that was the fix.
93 zj/4.0/aw4/300/44/70
This is the classic "Unstoppable Force" versus "Immoveable Object" debate. The result? Destruction of the Universe.
last time i tried fording a river 2 of my oxen died and i got dysentary
Nick ZJ is offline
post #6 of 9 Old 04-21-2006, 10:13 PM Thread Starter
chuck444
Suggestions
I may have misspoken earlier about turning over. Someone at work told me that it is turning over (the noise that sounds like it is trying to start). My lack of car knowledge. Any suggestions with this new piece of info.
chuck444 is offline
post #7 of 9 Old 04-21-2006, 11:26 PM
Virmagicus
Virmagicus's Avatar
Push gas pedal all the way to the floor and try starting it . Your codes are fine .
Jeff
Virmagicus is offline
post #8 of 9 Old 04-23-2006, 06:42 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Any luck? Makes me sick to think that there is a dead ZJ out there
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #9 of 9 Old 04-23-2006, 09:05 AM Thread Starter
chuck444
Thanks
Thanks guys for all your help!! I had a friend come over and help me out. It was a combination of all your information and someone who had the skills to apply what you suggested. This is what was done:
·New battery (the old one was really beat)
·Cleaned the air intake (I think that is what it is called) it had a lot of build up on it
·Cleaned the rotor, distributor cap, and some of the spark plug wires of some corrosion
·Then tried to start it with the gas pedal to the floor
·It had a difficult time but started
·Then we replaced the rotor, distributor cap, air filter, ignition coil, and also added some fuel injection cleaner to gas tank
·Runs ok for now
Needs more maintenance but it is running for now. Next task is to change the spark plugs, wires and replace the gasket. It leaks oil on a regular basis.
Thanks again for all your help!!
chuck444 is offline
WTB ECM for 1993 Jeep Grand Cherokee Limited eprissel ZJ Grand Cherokee Forum 15 10-18-2010 02:14 PM
1993 Jeep Grand Cherokee Limited 5.2 serdartimur ZJ Grand Cherokee Forum 0 07-30-2008 07:22 AM
PCV Or CCV Valve On 1993 Jeep Grand Cherokee Dave2002 ZJ Grand Cherokee Forum 6 03-22-2007 03:40 PM
1993 Jeep Grand Cherokee magimoo ZJ Grand Cherokee Forum 1 05-31-2005 12:29 AM
1993 jeep grand cherokee limited lee8431 ZJ Grand Cherokee Forum 2 12-10-2001 02:25 AM
