1993 Jeep Grand Cherokee fuel leakdown problem. - JeepForum.com
post #1 of 7 Old 06-14-2010, 11:58 AM Thread Starter
Jess1256
1993 JGC 5.2 Liter V8 Limited. Having issue with keeping the fuel pressure up in the fuel rail. Using quick start the engine can be made to run after a quite few tries, runs nice, too, though it won't start-up after sitting over night, but will keep fuel in the rail for only a few hours and starts right up in that time and will run endlessly. But if not started every few hours, all the fuel seems to drain from the rail and back to the tank. There doesn't appear to be any fuel leaks and no strong smell of fuel. I am hoping someone might have a suggestion that I have not thought of. Fuel pressure regulator , although I have no means to actually test it, and it's vacuum seems to be fine. It is a 1993 5.2 so the FPR is on the back end of the fuel rail and has a vacuum going to it from the intake manifold. Perhaps it is the fuel pump? Might it cause such a thing if it's on it's way out? Any advice or a point in some direction would be greatly appreciated.
Love the forum, by the way. Great resource and lots of great people. Thank you for any help you might offer. Have a nice day.
Jess1256 is offline
post #2 of 7 Old 06-14-2010, 02:54 PM
Craft95ZJ
1986 MJ Comanche
It sounds like you have a possibility of leaky injectors leaking into the cylinders and flooding the engine. If it runs good then perhaps you have a good fuel regulator. On the other hand your check valve could have gone out, but it should start and run without a check valve. Something to check anyways.
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #3 of 7 Old 06-14-2010, 04:33 PM
classicmetalman
Leaning towards the check valve. IIRC, check valve is supposed to hold pressure in line when off. Tried priming it before a cold start?
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #4 of 7 Old 06-14-2010, 09:24 PM
-Joe-
-Joe-'s Avatar
The fuel pump will run for ~1 to 2 seconds when your first turn the key to prime the rail. Even with a leak down situation it should still start after that.
Are you saying it wont start at all? Or just not within the first few cranks?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 7 Old 06-15-2010, 04:34 PM Thread Starter
Jess1256
It will start after being primed, either with alot of tries with quick start of priming the line. And then, after many tries of it starting, idling for a few seconds, it will run normally, lots of power then and getting plenty of fuel, drives fine once it is running and does not stall. But after a few hours of sitting it will lose it's prime and the rail will have no pressure and the whole process must be done again for it to start and run again. Thanks for the suggestions. I am going out to check out the check valve in a bit. Thanks again and have a nice day and happy jeeping.
Jess1256 is offline
post #6 of 7 Old 06-15-2010, 05:01 PM Thread Starter
Jess1256
It will never crank over on it's own. Must be primed first, or quick started multiple times till fuel is sucked or pushed up to the rail
Jess1256 is offline
post #7 of 7 Old 04-23-2015, 12:44 AM
rotfoot
Hey i know this.forum is an old post but did you figure out the issue? I have the same exact issue in a 93 cherokee 4.0.
rotfoot is offline
1993 zj , 5.2l , fuel pressure regulator , fuel system , help please
93 Jeep Grand Cherokee Laredo Fuel Problem? Dave2002 ZJ Grand Cherokee Forum 3 06-20-2011 12:24 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
1993 Jeep Grand Cherokee Help chuck444 ZJ Grand Cherokee Forum 8 04-23-2006 09:05 AM
1993 Jeep Grand Cherokee magimoo ZJ Grand Cherokee Forum 1 05-31-2005 12:29 AM
1993 Grand Cherokee died a few mins ago, whats the problem? arkman ZJ Grand Cherokee Forum 4 02-27-2003 07:47 AM
