1993 grand waggon 5.2L V8 flooding out - JeepForum.com
post #1 of 5 Old 11-03-2009, 11:10 AM Thread Starter
ECMUDSLINGER
here it is 1993 grand wagoner ZJ body tho with a 5.2L V8.It is flooding out bad you can smell raw fuel strong and the plugs are soaked by gas and the oil is getting fuel in it to.it also emits a lot of black smoke with a lil white. I'm tired of trying my local mechanics it doesn't have odb1 or odb2 making it impossible to check it on a computer.I was told by a few people maybe the cam sensor and def the O2 sensor cause running it so rich can burn it out...please comment if u can help......THANX ECM
ECMUDSLINGER is offline
post #2 of 5 Old 11-03-2009, 12:46 PM
impuresoul2k3
1) You have a ZJ, not an FSJ, change your profile.
2) It has ODB-1, that's how you can do the on-off-on-off-on trick and pull codes.
3) If you don't have any codes, unplug the battery, disconnect the o2 sensor, and see if it behaves the same way. That will let you know if the O2 is bad.
4) FPR could also be bad.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #3 of 5 Old 12-01-2009, 11:02 PM Thread Starter
ECMUDSLINGER
Still cant figure out the odb-1 deal i think my computer needs help ? but replaced the O2 sensor it did well for a week, then many more problems.The FPR is brand new also. Thanks
post #4 of 5 Old 12-01-2009, 11:08 PM
Ricochet88
mine will do the on off code puller thing it took me a few tries to get it to work the first time
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #5 of 5 Old 12-01-2009, 11:35 PM
Virmagicus
Virmagicus's Avatar
The ON-OFF-ON-OFF-ON Trick
Jeff
Virmagicus is offline
1993 ZJ' grand wagoneer?? trickle26 ZJ Grand Cherokee Forum 6 01-07-2012 02:33 PM
93 5.2 grand waggon ECMUDSLINGER ZJ Grand Cherokee Forum 6 07-08-2009 06:56 PM
1993 grand wagoneer, red box??? debago ZJ Grand Cherokee Forum 23 10-21-2007 09:38 AM
1993 Grand still heating up WBowie ZJ Grand Cherokee Forum 26 07-31-2007 05:00 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 12:16 PM
