1993 Grand Cherokee died a few mins ago, whats the problem? - JeepForum.com
post #1 of 5 Old 02-26-2003, 06:41 PM Thread Starter
arkman
I have a 1993 Grand Cherokee V8 4WD and it is having some crazy electrical problems. It sleeted really bad on Monday and it has been frozed and iced over everwhere here since. Today it melted and i had to go so im driving for a while and the gauges go out and the lights go out, the stereo, just the accessories, not the power steering etc. But i go over a speed bump on the way home and it all turns back on. So i pull over with the engine still on, and check the battery connection. It seems fine but then the engine cuts off. So i get in the car and i try to start her back up, but it wont turn over. What do yall think is the problem? I just spent a lot of money in getting the car fixed and got it back yesterday, i hope its not major.
Thanks,
Noah
arkman is offline
post #2 of 5 Old 02-26-2003, 06:54 PM
KillerZJ
KillerZJ's Avatar
god that sucks. i have no idea what it could be. definately electrical problems. do you think it could the the ingnition not sending anything to the plugs or anyting. if that helps.
Looking for E36 325i(s) 5 speed only. Jeep is for sale $3,000 takes it. E-mail only.
*Sale Pending*
Wow no pictures in sig? F*cking gay.
KillerZJ is offline
post #3 of 5 Old 02-26-2003, 08:18 PM
TOM380
Check your main ground. There should be a main ground cable going from the body to the sub frame if you have a chiltons or clymer manual it should show you there. I had the same problem with my 94 F-150. The main ground is very important and will cause similar problems to what you are seeing.
1997 ZJ 5.2L V8,K&N AIR FILTER,FLO-MASTER EXHAUST 2"BB LIFT 30" REMINGTON WIDE BRUTES. ProComp ES3000 SHOCKS, CUSTOM SPARE TIRE CARRIER AND ROOF RACK,HELLA LIGHTS. JUST GETTING STARTED!!!!!
1968 Jeep (Kaiser) Wagoneer, Buick 350 V8, Isky cam,HEI ignition, TH400 trans and completly stock inside and out.
TOM380 is offline
post #4 of 5 Old 02-26-2003, 10:11 PM Thread Starter
arkman
alright, well, i got the car running without a jump after letting it sit for 30 minutes and then i drove out 30 minutes to drop off my bro. Then when i tried to start the car again after hangin out for an hour, it was dead. I got a jump and it started so i am gonna replace the battery tomorrow and hope that is it. I am sure there is something else that is wrong, some kind of short or something in the dash... ill put that off though cuz it will prolly be expensive.
arkman is offline
post #5 of 5 Old 02-27-2003, 07:47 AM
blackbelt
blackbelt's Avatar
Main ground, as has been mentioned, battery cable, or ignition switch.
2001 XJ Sport
2007 Caliber R/T AWD
2000 Subaru Forester
2006 Scion xB
1987 VW Wolfsburg Cabriloet
1969 SAAB 96 V4
blackbelt is offline
99 Grand Cherokee Died today... Help twmart ZJ Grand Cherokee Forum 9 03-26-2017 10:43 AM
1998 Grand Cherokee Laredo overheating after 5 mins. BlessingD ZJ Grand Cherokee Forum 9 07-20-2008 01:52 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
93 grand cherokee just died my94cherokee ZJ Grand Cherokee Forum 3 09-04-2006 09:15 PM
grand cherokee died freeburg ZJ Grand Cherokee Forum 4 11-29-2005 08:28 PM
