1993 GC 4.0 I6 starting problem - JeepForum.com
post #1 of 1 Old 01-09-2011, 12:00 PM Thread Starter
Kingjere
Ok guys, I new to the forums and need some help. I have a 1993 GC with a 4.0 I6 that is very difficult starting. It needs to be cranked several times before starting. When it does start it does not act as if it is flooded, rather starved for fuel. Starting usually occurs after one or two cycles of the key switch.
What I've done:
- New fuel pressure regulator, and test correctly on the pressure test
- New Fuel filter
- Fuel pressure tested, running psi 31, idle psi 30 psi, max psi 39
(vacuum hose disconnected)
- All fuses and relays test correctly
- The Fuel pump seems to operate normally during starts, idle and normal
operation, meaning it turns on and seems to pump fuel normally
- Oh and no noticeable leaks
- ABSOLUTELY NO CODES ON THE COMPUTER
My questions:
The fuel pressure will fall to 0 in the fuel injection rail after 35 min, any
ideas on the causes??? I'm assuming this is causing a fuel starvation issue on start up an would explain the rough start issue.
- Possibly a failed schrader valve (valve-stem looking valve on the
fuel rails) causing a bleed down?
- A bad fuel pump?
- Is there a check valve I'm not seeing?
- A leaky injector?
Kingjere is offline
fuel pressure , fuel pressure regulator , fuel pump , starting issue , starting problem
1993 Jeep Grand Cherokee fuel leakdown problem. Jess1256 ZJ Grand Cherokee Forum 6 04-23-2015 12:44 AM
1993 Abs Problem Help! nprice24x ZJ Grand Cherokee Forum 3 07-15-2010 07:36 AM
1993 GC transmission engagement problem neelix6555 ZJ Grand Cherokee Forum 3 12-04-2008 08:18 PM
1993 Grand Cherokee died a few mins ago, whats the problem? arkman ZJ Grand Cherokee Forum 4 02-27-2003 07:47 AM
1993 Jeep G. Cherokee Paint Problem jeff_connors ZJ Grand Cherokee Forum 6 10-16-2002 04:56 PM
