1993 AW4 trans into a 1996 4.0 - JeepForum.com
post #1 of 5 Old 07-22-2009, 02:26 PM Thread Starter
drespecki
1983 CJ7
I heard the 1993 Grands with the 4.0 had the AW4... Will that swap into my 1996 Grand with the 4.0 and what will I need to take off the 1993 to make it work properly? I just want it as a spare if it will work PERFECTLY... Thanks..
It only hurts while you're breathing..
drespecki is offline
post #2 of 5 Old 07-22-2009, 02:36 PM
tfgnt16
2009 WK
AW4 is pre OBDII, it probably will not work with a 96+ PCM/ECU and there would be way too much work involved in getting it to work perfectly, if it is even possible.
2001 WJ Laredo 4.0L - Sold!
2009 WK Limited 5.7L HEMI
tfgnt16 is offline
post #3 of 5 Old 07-22-2009, 06:27 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
tons of screwing around.
ratmonkey is offline
post #4 of 5 Old 07-22-2009, 07:47 PM
JrMechanic
It's been done. There's a thread around here somewhere. However it's not the easiest of swaps. the AW4 was only available in the early 93's (first couple months) then they all went to the 42RE.
Whats wrong with the current transmission? Nothing wrong with a 42RE.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #5 of 5 Old 08-05-2009, 05:29 PM Thread Starter
drespecki
1983 CJ7
My 42re works well but I have a line one a free AW4 to swap in when mine kicks the bucket. It has about 160k on it now.. Just saving things up for the future..
Saving a AW4 trans setup from a 1993 drespecki ZJ Grand Cherokee Forum 4 11-24-2009 05:21 PM
1993 46RH trans has noise and shifting issues skilled1 ZJ Grand Cherokee Forum 3 06-10-2009 09:31 AM
1996 Jeep Grand Cherokee Trans Problems FOoLieo ZJ Grand Cherokee Forum 10 05-12-2008 12:50 PM
Switching a 1993 front bumper for a 1996 pgv98 ZJ Grand Cherokee Forum 3 06-10-2007 12:34 PM
1996 Laredo issues; trans; oil pressure Bokonon69 ZJ Grand Cherokee Forum 4 05-06-2006 09:25 PM
