1993 5.2 ZJ New 46RH Late Shift into 3rd - JeepForum.com
post #1 of 7 Old 10-17-2013, 10:00 AM Thread Starter
Duffman2613
So I found a used 46rh tranny for $250, so I said screw replacing a crap ton of sensors just to attempt to fix OD and just decided to replace the whole thing. Which turned out to be a good idea anyway because doing so I found out how much metal shavings were on the tranny pan. Not good.
Well I now have OD, but it shifts pretty late into 3rd gear. It won't shift until about 2500-2700 rpms (35 mph) and it shifts once almost immediately afterwards and again about 5 mph later. So this is my question... What is this more likely to be, the bands needing to be adjusted or the TV cable? I'm not sure, I was leaning more towards the TV cable because when it's too tight it'll cause late shifts and harder shifts. And another thing, why is it shifting 5 times? It's definitely 3rd gear that it shifts into late, why are there two more shifts afterwards?
Thanks
Duffman2613 is offline
post #2 of 7 Old 10-17-2013, 10:11 AM
JohnnyZJ
shifts into third, then it locks torque converter, then kicks into OD.
did you flush the 'new' tranny out with new fluid and give it a new filter? if not do that. i'm guessing you haven't dropped the pan on this tranny yet have you? FYI the OD solenoid takes 10 minutes to replace after you drop the pan.
as for the hanging in second gear issue; mines been doing that for 4 years now. i'm used to it so i know how to drive with it. i prefer that then ****ing with it and making it worse. 'non issue' to me now....... then again the jeeps 18 years old so i don't expect much from her these days lol
07' JKUR rollin on 35s
JohnnyZJ is offline
post #3 of 7 Old 10-17-2013, 11:09 AM Thread Starter
Duffman2613
Okay that makes more sense. And yes, I did drop the pan, flush the fluid and replace the filter. The filter and fluid looked new. But i had a new filter and fluid so I just replaced them anyway. Your's hangs in 2nd until 2700 rpms though? And does it shift pretty hard? It's just weird to me cruising at 30mph and it just drags in 2nd. I like it more for when I wanna step on it, but not always.
And thanks
post #4 of 7 Old 10-17-2013, 01:46 PM
JohnnyZJ
yea man.
it does the exact same thing. just coasting it won't go until 2500 at least. sometimes more. i stopped caring about it and now i just hammer it everywhere lol.
1st to second is a very hard shift. 2-3 is better. still feel it. 3-4 fairly smooth.
i said 'screw it, if its on its way out i'll swap it when it dies' that was 4 years and 40k ago...... it shifts firm and doesn't slip so screw it. its when it doesn't shift firm and slips you have a problem.
i'm not sure if playing with stuff like teh bands and stuff will fix it; thought that was for clutch material wearing off and stuff. i asked a mechanic buddy about adjusting the TV cable (because everyone here says to) and he laughed and said don't touch it.
so i said **** it and just driving it as is.
JohnnyZJ is offline
post #5 of 7 Old 10-17-2013, 02:06 PM
cdavern
Lucas additive in the pan and a small adjustment to TV cable made a huge difference, smooth shifting, at 250,000 miles and still going strong
cdavern is offline
post #6 of 7 Old 10-17-2013, 08:53 PM
Rich93ZJ
You have exactly described the shift pattern of my 93 also. I have dicked with TV cable , adjusted bands, ect. I said screw it like JonnyZJ and just live with it.
93 ZJ 5.2V8 3.5 iro 31x10.5
08 Silverado 6in lift 35's
Rich93ZJ is offline
post #7 of 7 Old 10-18-2013, 10:07 AM
JohnnyZJ
from the research i've done the shifting is all controlled through the governor, which is pressure activated, and it is located in the tailcone of the tranny, so basically i've come to the conclusion; keep fluid clean, make sure it doesn't overheat via clogged lines/tranny cooler, and drive it. when i pin it it down shifts, when i let off the gas it upshifts.
i'm not picky, lol
JohnnyZJ is offline
1993 zj , 46rh , transmission , v8
