1993-1995 ZJ: Keyless Entry Programming - JeepForum.com
post #1 of 5 Old 09-30-2012, 02:17 PM Thread Starter
94zj318
1994 ZJ
So I figured I'd tell you guys how to program a keyless entry remote to your 1993-1995 ZJ.
Here is the remote I used for my 1994 ZJ, bought off of eBay for what I think is a pretty good price ($170 at a dealer, $60 on eBay): http://www.ebay.com/itm/190679554318...84.m1439.l2649
It arrived quickly and in good condition. Here's how I programmed it, following the procedure in the owner's manual (figured I'd post this just in case your ZJ didn't have the owner's manual when you purchased it):
First, you need to determine if your ZJ even had keyless entry to begin with. If you see a black dome in the roof, your ZJ had keyless entry. If not, then your ZJ did not come with keyless entry, and you'll have to go the aftermarket route. If your ZJ had keyless entry, here's how to program it:
1.) Make sure all doors, the liftgate, and the hood are all closed.
2.) Get into the driver's seat and shut the door.
3.) Put one of your keys into the ignition, but do not turn it yet.
4.) Open the driver's door and manually slide the lock switch from the unlocked position (orange) to the locked position (black).
5.) Start your ZJ like normal.
6.) Hold the keyless entry remote up to the little dome in the roof. Hold down 'Unlock' on the keyless entry remote (the button on the left) and do not let go of it until the red LED on the keyless entry remote blinks rapidly. You should hear the door locks cycle.
7.) Shut your ZJ off within twenty (20) seconds. Try out your keyless entry remote and make sure it works. That's it!
94zj318 is offline
post #2 of 5 Old 01-06-2013, 10:28 PM
dnuccio
this should be put in the FAQ's!!!!!
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 5 Old 06-07-2015, 02:17 PM
esu
old thread but how do you program an additional remote?
esu is offline
post #4 of 5 Old 06-07-2015, 02:29 PM
kg6mov
Hears the voices
kg6mov's Avatar
Repeat step 6 for all remotes. Starting the procedure erases any learned remotes.
kg6mov is offline
post #5 of 5 Old 06-07-2015, 04:06 PM
esu
thx
esu is offline
1993 , 1995 , keyless entry , programming , zj
Programming a keyless entry? silent35 ZJ Grand Cherokee Forum 1 08-25-2012 02:48 PM
Programming a keyless entry? silent35 ZJ Grand Cherokee Forum 2 08-09-2012 01:26 AM
Keyless entry programming Lucky12680 ZJ Grand Cherokee Forum 3 07-07-2009 02:28 PM
Programming keyless entry for 97 ZJ rickd. ZJ Grand Cherokee Forum 6 05-30-2006 11:33 PM
Programming Keyless Entry Help CRCoatings ZJ Grand Cherokee Forum 6 11-29-2004 03:40 PM
