1991 Jeep Wrangler - JeepForum.com
post #1 of 5 Old 05-25-2011, 08:22 PM Thread Starter
mumbulob
1991 Jeep Wrangler
How hard is it to replace the hydrolic clutch, mater cyling and the slave cylinder. Also where is the slave cylinder and master cylinder located
mumbulob is offline
post #2 of 5 Old 05-25-2011, 08:51 PM
blackjack12982
1994 ZJ
On the Wrangler? You'd get alot more detailed answers if you posted this in the Wrangler area of the forum...
blackjack12982 is offline
post #3 of 5 Old 05-25-2011, 09:41 PM
TallyZJ
Right! Uhm . . . whut the hell is a Wrangler anyway??
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #4 of 5 Old 05-26-2011, 02:16 AM
BlueDevil
FWIW, master clutch cylinder is a breeze to replace: bend down to disconnect the clutch pedal (round thingy keeps the pin through the pedal), then open hood, remove two bolts holding master cyl bolted to firewall (that's the thing where you'd put clutch oil in, that's your master cyl). Disconnect tubes, taking care not to leak fluid and to let as little air in as possible. Connect tubes to new cyl, bolt back in, add oil. Pumping the pedal will force the air bubbles to go out eventually.
As for slave cyl, it could be on the inside the bell or the outside. If I remember correctly, your's would be inside the bell, which means more job since you have to disconnect the tranny from the engine to gain acess inside to swap the slave cyl. To double-check its location, just follow the line from master cyl down to tranny. If it ends in an oval-shaped thingy outside the tranny, then it's on outside (I don't belive it is, though). If not, get ready to unbolt the tranny...
If you're changing BOTH your cyls, then get them as a pair with the tube and oil in, all aired-out. Saves a lot of trouble chasing them bubbles outta there.
On mine only the master was kaputt, so I changed only that one, and all was well again. Good luck.
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #5 of 5 Old 05-26-2011, 02:50 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
1991 is an internal slave trans.
not a fun job in the least.
ratmonkey is offline
Jeep Wrangler Wheels on Grand Cherokee? perrypel ZJ Grand Cherokee Forum 8 05-04-2011 11:16 PM
Tire Pressure Sensors from 2009 Jeep Wrangler X jdharri7 ZJ Grand Cherokee Forum 3 07-21-2009 05:28 PM
tow a wrangler bigstinger ZJ Grand Cherokee Forum 2 08-17-2008 06:29 PM
Wrangler Gas cap on ZJ zjeepin ZJ Grand Cherokee Forum 18 01-10-2006 08:34 PM
Why having a GC is better then a Wrangler. ZJ_COWBOY ZJ Grand Cherokee Forum 19 10-04-2004 09:25 PM
