12 Things You Can Do When Your ZJ Stalls - Page 6 - JeepForum.com
 7Likes
post #76 of 435 Old 06-21-2013, 04:05 PM
DickDickle
When my jeep stalls I have to pull the 20 amp fuse from the junction block for the pcm/asd for a few seconds put it back in and it fires right up some days it will stall four times in one trip some days it never acts up
DickDickle is offline
post #77 of 435 Old 06-21-2013, 06:33 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I'll start a vote to get this is the stickies, right after i get my free trailer hitch Zee always does good diligent work.
Originally Posted by HighLonesome
coralman is online now
post #78 of 435 Old 06-21-2013, 06:40 PM
JS97ZJ
You know you'll get my vote.
JS97ZJ is offline
post #79 of 435 Old 06-21-2013, 08:09 PM Thread Starter
ZeeJay1997
Originally Posted by mcp2009 View Post
if anyone has any guesses or assumptions please let me know
You are a prime candidate for #4, then 3.
ZeeJay1997 is offline
post #80 of 435 Old 06-21-2013, 08:12 PM Thread Starter
ZeeJay1997
The PCM is suspect, but could be something reverse biasing one of the circuits or possibly a bad ground on the engine block.
Also try swapping ASD relay with horn relay.
post #81 of 435 Old 06-21-2013, 08:14 PM Thread Starter
ZeeJay1997
Originally Posted by coralman View Post
I Zee always does good diligent work.
Dont tell anyone, you'll ruin my reputation
post #82 of 435 Old 06-21-2013, 08:19 PM Thread Starter
ZeeJay1997
It already has more hits than the rules and guidelines.
post #83 of 435 Old 06-23-2013, 07:27 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
This thread was just added to the faqs page. Thanks ZeeJay for the hard work.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #84 of 435 Old 06-26-2013, 08:07 AM
DickDickle
So I ended up swapping my asd relay with the horn relay and noticed no change, I also tried a brand new relay with no change. I had a few computers in stock so I changed the computer out but before doing so I scanned the jeep for codes and the only code that came up was number 42 for high fuel volts. I disconnected the battery and swapped computers, I have not experienced any stalling yet but I did notice that on my way to work this morning my fuel Guage was at about half a tank and while sitting at a red light it dropped to e and never came back where as with the old computer if the fuel level would drop to e and a few seconds later it would return to normal. Wouldn't that be a sending unit problem or could the computer have something to do with that too? I have one more spare computer I could try and I just want to mention that all three computers I have do have the exact same part numbers on them
post #85 of 435 Old 06-26-2013, 11:01 AM
DickDickle
I know that the dtc code 42 can also be for low fuel voltage or for the asd I don't know if this code has to do with errartic fuel level display or not
post #86 of 435 Old 06-26-2013, 12:15 PM
DickDickle
Just went to swap in computer number 3 and before I did I scanned it again and got dtc code 11 disconnected the battery put the 3rd computer in went to pick up lunch drove about 5 miles and the jeep died going down the road right in front of the shop luckily, I opened the central junction box pulled out the 20 amp mini fuse put it back in and the jeep restarted normally could this be the start of a bad cps? I scanned it after the stall and my scan tool is showing no codes.....
post #87 of 435 Old 06-26-2013, 08:31 PM Thread Starter
ZeeJay1997
yes it sounds like either the CPS or O2 sensor is shorting the 5v sensor supply. try disconnecting o2 sensors. you'll get a code, but if it quits stalling, you'll know what the problem is.
If that doesnt work, you are probably looking at a failing CPS.
The fuel gauge problem you described on the other PCM could be caused by the PCM, guage or fauly connection at the fuel tank.
I'm assuming since you posted on this thread that you have gone through all of the troubleshooting?
post #88 of 435 Old 06-26-2013, 09:41 PM
DickDickle
I have gone through all of the trouble shooting I'm now curious of the cam position sensor because I'm getting 5v at the plug but only getting a little over 3v on the sensor side. I'm gong to put it on the scope tomorrow to get a better idea of what is going on I will take some pictures of the readings I tried switching the crank position sensor with no change it stalled 5 times on a 16 miles ride this evening
post #89 of 435 Old 06-27-2013, 05:13 AM Thread Starter
ZeeJay1997
You're rotating the crank I presume? On mine the engine usually stops with the field collapsed. When I go to the output wire with the key on, I get 5V.
post #90 of 435 Old 06-27-2013, 06:43 AM
DickDickle
I tested it running I have test leads the thickness of safety pins so I can tap right into the wires
grounds , hesitation , no start , stalling , wiring
95 ZJ stalls? longtravel1 ZJ Grand Cherokee Forum 2 09-06-2011 11:12 PM
Stalls when low on gas. sk8tgk ZJ Grand Cherokee Forum 3 10-08-2010 01:34 PM
stalls toolman401 ZJ Grand Cherokee Forum 1 02-18-2010 07:19 PM
95 4.0 stalls when off the gas liredneck ZJ Grand Cherokee Forum 8 04-20-2009 07:45 PM
Please HELP my 95 Zj stalls wrestlerobx ZJ Grand Cherokee Forum 43 05-18-2008 09:58 PM
