12 Things You Can Do When Your ZJ Stalls - Page 21 - JeepForum.com
 7Likes
post #301 of 437 Old 03-16-2014, 12:59 PM
T-rexx
Originally Posted by ZeeJay1997 View Post
everything that's highlighted and check all cables
Will do tomorrow. It's raining right now
"EVERY TIME I FIX ONE THING I BREAK TWO MORE"
T-rexx is offline
post #302 of 437 Old 03-21-2014, 06:49 PM
MadDog96
Zeejay, The Mechanic called me this morning and told me to dump the '96 off on someone else, so I did. I took it to my friendly dealer and he gave me what I had tied up in it on trade on a 2001 G.C. with all options that the other one had. My problems are now the dealer's and I'm cool with that! I got back all the money I had invested in "The Ghost Jeep" and got a very clean, good running, newer model for not a lot of "boot"! Thanks to you and the others on the forum for all the advice I was given during my dilemma with the '96.
MadDog 96
MadDog96 is offline
post #303 of 437 Old 03-21-2014, 07:16 PM Thread Starter
ZeeJay1997
I'm glad we got that one fixed!
ZeeJay1997 is offline
post #304 of 437 Old 03-21-2014, 08:32 PM
dusterdude
Damn dog,we're gonna miss ya
dusterdude is offline
post #305 of 437 Old 03-22-2014, 06:14 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Good luck dog! Just a tip, keep the cooling system in tip top shape and don't let it overheat. The 0331 head had some cracking problems.
Originally Posted by HighLonesome
coralman is offline
post #306 of 437 Old 03-22-2014, 03:19 PM
MadDog96
Forum Friends, I ain't going anywhere just because I went WJ. I'm sure some things will pop up from time to time. I'll still need some advice, I'm sure. Yep, ZeeJay, We fixed that one. I'm wondering about the next guy that ends up with it, guaranteed he'll show up on here sooner or later! We will just have to determine whether or not the poster got "The Ghost Jeep". If he does have all the stress I had we can advise him to pass it on to the next person until it finally ends up in the boneyard!
MadDog96 is offline
post #307 of 437 Old 03-22-2014, 03:26 PM
-OIIIIIIIO-01
-OIIIIIIIO-01's Avatar
Welcome to the WJ side! Beware if you have all the bells and whistles though, lots of problems with that stuff.
91 YJ 4.0/AX15/231 D30/8.8LSD
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is online now
post #308 of 437 Old 03-22-2014, 03:27 PM
MadDog96
Thanks Coralman, I'm pretty religious about checking fluids, belts and any items that can go out without notice. Being a truck driver for over twenty yrs. I generally pop my hood every morning before starting up and checking every thing I can see that could possibly give frowns or make me pull my hair out like "The ghost Jeep" did!
MadDog
MadDog96 is offline
post #309 of 437 Old 03-22-2014, 03:31 PM
MadDog96
OIIIIIIIO-O1, When I popped the hood this morning, I could swear somebody stole my distributor and plugged the hole with some weird lookin' kind of sensor!
MadDog96 is offline
post #310 of 437 Old 03-22-2014, 04:47 PM Thread Starter
ZeeJay1997
you should have put a card behind the pcm that says "ghost jeep, jeepforum.com"
post #311 of 437 Old 03-22-2014, 08:00 PM
MadDog96
ZeeJay, Or maybe a card behind the PCM that says "Ghost Jeep get rid of me fast. Call the nearest Recycler as soon as possible, Sincerely, MadDog96"
MadDog96 is offline
post #312 of 437 Old 03-23-2014, 06:53 AM
Mjczj
Hello,
My 4th GC. Had original GC in '93. Turns out ZJ was my favorite. Just bought a abused '97 w/ 170k. Seller "forgot to tell me about the stalling problem. This forum helped a lot. Replaced battery, got it running and started checking the wiring. Jiggled PCM harnesses, Bingo! That was my problem. Took PCM out and scraped all pins on the harness w/ exacto knife. So far so good. It has been said most problems are w/ PCM, I'll bet this is the problem for most. Thanks for the help.
Mjczj is offline
post #313 of 437 Old 04-10-2014, 05:43 PM
terry76555
For anyone who is interested in another GC No Start... 1996 GC 107k miles, 5.2L
No starts began the other morning. Engine cranked but thanks to this thread from ZeeJay and others, I looked for the CEL, found a whirring fuel pump and no CEL. Also no gauge readings and the low fuel light displayed.
- After battery charge, cleaning some grounds and terminals, sometimes it would give me a CEL and sometimes no.
- When I got a CEL and could get gauge voltages for the ON position, they ranged from high 11s to possibly a 12.5. When running, near 14v.
- I did some testing and battery boosts over a few days expecting to tie the issue to lower voltages. No apparent correlation.
- BTW, whenever I got a CEL, GC started and ran fine (not counting TPS relearning).
- Also turns out I typically started messing with this in the AM in the shade and would get CELS by mid afternoon (right in the afternoon sun).
So my current theory is that the PCM does not want to work when cool/cold.
- No joy Tuesday following rain.
- CEL / start / ran fine Wed and today in the afternoon (bright FL sun right into the PCM area)
- After sundown, and cool down, no CEL / no start.
- So, got the heat gun out set it on low pointed at the PCM, turned the key to on and got CEL withing about 60 seconds.
Friday morning will try the cold PCM and heat gun again and if results are the same will get a PCM.
Thanks again to ZeeJay and all of you who have contributed to all this.
terry76555 is offline
post #314 of 437 Old 04-10-2014, 05:54 PM
DickDickle
Because of this thread I have figured out everything except for my codes for tps high voltage and my fuel level having voltage
DickDickle is offline
post #315 of 437 Old 04-10-2014, 06:00 PM Thread Starter
ZeeJay1997
Originally Posted by terry76555 View Post
F
thank you for the feedback. let us know if the pcm fixed it. i need to add your heat gun trick to the PCM section.
grounds , hesitation , no start , stalling , wiring
95 ZJ stalls? longtravel1 ZJ Grand Cherokee Forum 2 09-06-2011 10:12 PM
Stalls when low on gas. sk8tgk ZJ Grand Cherokee Forum 3 10-08-2010 12:34 PM
stalls toolman401 ZJ Grand Cherokee Forum 1 02-18-2010 06:19 PM
95 4.0 stalls when off the gas liredneck ZJ Grand Cherokee Forum 8 04-20-2009 06:45 PM
Please HELP my 95 Zj stalls wrestlerobx ZJ Grand Cherokee Forum 43 05-18-2008 08:58 PM
