12 Things You Can Do When Your ZJ Stalls - Page 17 - JeepForum.com
 7Likes
post #241 of 435 Old 02-25-2014, 07:10 PM
bublackey
1994 XJ Cherokee
ok pretty much sums up he fried my ECM by crossing the 02 sensor..................you don't have to have them programed for a 94 grand Cherokee Laredo do you?
bublackey is offline
post #242 of 435 Old 02-25-2014, 08:14 PM
cgcarpenter
Repair the wires to the o2 sensor before hooking up new ECM
cgcarpenter is offline
post #243 of 435 Old 02-25-2014, 08:21 PM
bublackey
1994 XJ Cherokee
I put a new sensor in.....lmao cant find my part number on my ECM no sticker on it anywhere does it have to be same part number or can it be from another jeep same as mine if it has to be same part number how can I find it lmfao will be last question I ask anyone
post #244 of 435 Old 02-25-2014, 08:45 PM Thread Starter
ZeeJay1997
if your vehicle has a security system and you want to put a used one on it, the donor must also have security. same deal if you do not have security, the donor cant have security. if you get a refurbished one it doesnt matter.
if you cant get your replacement to work, please start a new thread. thanks and good luck
ZeeJay1997 is offline
post #245 of 435 Old 03-02-2014, 03:36 PM
MadDog96
ZeeJay, It's MadDog again. I put on the Mopar CKPS today. No change. It's still lopping at idle, dying when giving it fuel, quitting just anytime it wants to. After changing all of the sensors, new PCM and new fuel pump and filter, do you think it could be a weak coil that fails whenever put under a load? All grounds are wire brushed and cleaned at all grounding points, All the fuses and relays have been cleaned and sanded, and checked to be good, battery terminals cleaned, all positive connections have been taken apart and wire brushed and cleaned. All of the 12 things to check, as per the list. The coil is the only thing left! When it dies, I can still coast, put it up in neutral, and it starts right back up, runs for a little while, then repeats the symptoms.
Brother, I AM STUMPED! I just love throwing money at this thing!. No codes coming up except 12&55
MadDog96 is offline
post #246 of 435 Old 03-02-2014, 04:58 PM Thread Starter
ZeeJay1997
You've pretty much ran the gauntlet. If you haven't done so already, try to restore the tension on the PCM connectors and elongate the sockets on the coil connector so they make better contact. Coils can fail under load and they can be checked with a meter. There are some links you can follow in the ignition section.
post #247 of 435 Old 03-02-2014, 06:41 PM
MadDog96
ZeeJay, Thanks. Is the Standard brand coil reliable ? There's all kinds of brands on E-Bay, some pretty pricey. I'm going to try and order one tonight.
Thanks again. Maddog96
MadDog96 is offline
post #248 of 435 Old 03-02-2014, 07:23 PM Thread Starter
ZeeJay1997
i dont know, my oem coil is still going at 178k
post #249 of 435 Old 03-02-2014, 08:54 PM
MadDog96
ZeeJay, I figure why not at 231K? I've Replaced everything else that was OEM, There's always that chance I've been barking up the wrong tree the whole time! But, I swear, all the sensors, PCM, exhaust mods, fuel pump & filter I've done on this thing has shown to be a slight improvement each time over what I started with! I'll let you know how it comes out. It seems like now, All I've got is time to work on stuff.
Thanks Man! MadDog96
MadDog96 is offline
post #250 of 435 Old 03-07-2014, 01:01 PM
MadDog96
Zee Jay, The new coil was of no help. Still lopping, stalling, quitting randomly, I've done all I can Do! FOR SALE ONE Jeep Grand Cherokee 4.0 I-6/ W/ ghosts. Buy it before I call the crusher!
MadDog96 is offline
post #251 of 435 Old 03-07-2014, 06:01 PM Thread Starter
ZeeJay1997
Sorry you couldnt fix it. it takes a lot of patience to own one of these things. i think just about everyone on the forum has made the "i'm getting rid of it" statement.
did you ever try restoring the PCM sockets?
post #252 of 435 Old 03-07-2014, 08:09 PM
phitmein
phitmein's Avatar
If you decide to send it to the crusher I would take all the new parts off it and save or sell them .
phitmein is offline
post #253 of 435 Old 03-07-2014, 08:35 PM
MadDog96
Well Zeejay, I guess in a moment of disgust, I have Let my temper override my logic. I have a nice chunk of change in this thing now and I'm still finding stuff wrong with it like all of the distributor terminals are loose in the cap, and you read my mind when you asked about restoring the PCM sockets, because when I got the new PCM, I just plugged it in, giving just a once over look at the sockets themselves. Every thing else is new, from front to back, either fuel or electrically related. My son's coming over tomorrow to put a new trans pan gasket on his 95, so I figure we can keep on studying the '96 until we get it right or decide to use it for parts. I guess I better run out and get some contact cleaner just to test the possibility of corroded sockets at the PCM. I've scoured this forum and corrosion seems to be the most problematic gremlin on most Jeeps. I've studied about restoring the sockets and it sounds rather intimidating with all those small wires, but if it can be done, I'm sure that It has by someone on this forum. Lots of good videos on here too, maybe I can search it out.
MadDog96 is offline
post #254 of 435 Old 03-07-2014, 08:43 PM Thread Starter
ZeeJay1997
maddog, read this
post #255 of 435 Old 03-08-2014, 07:36 AM
MadDog96
ZeeJay, I really appreciate your patience. Honest, I've read the Dirty Dozen, probably a dozen times or more. Every time I go over it, I find another item on the post that leads me to another probable cause of problems associated with this model of Jeep. Being a dyed in the wool enthusiast of Jeeps and the glitches that ensue, I can't give up on them, although at times it gets disgusting, especially this particular Jeep. I've even thought that maybe this one is a $30,000.00 factory original LEMON! Imagine that! I have now "Locked onto" the idea that I will get this one right, no matter what! I'll keep on plugging away at it. It has become a challenge to my psyche now. The most important thing I've learned is that there is no substitute for MOPAR parts when doing all this replacement stuff. I'll keep you posted as to any progress.
Thanks, MadDog96
MadDog96 is offline
grounds , hesitation , no start , stalling , wiring
Marcos
95 ZJ stalls? longtravel1 ZJ Grand Cherokee Forum 2 09-06-2011 10:12 PM
Stalls when low on gas. sk8tgk ZJ Grand Cherokee Forum 3 10-08-2010 12:34 PM
stalls toolman401 ZJ Grand Cherokee Forum 1 02-18-2010 06:19 PM
95 4.0 stalls when off the gas liredneck ZJ Grand Cherokee Forum 8 04-20-2009 06:45 PM
Please HELP my 95 Zj stalls wrestlerobx ZJ Grand Cherokee Forum 43 05-18-2008 08:58 PM
