12 Things You Can Do When Your ZJ Stalls - Page 10 - JeepForum.com
 8Likes
post #136 of 440 Old 09-18-2013, 06:13 PM Thread Starter
ZeeJay1997
Originally Posted by AnotherRedZj View Post
this thread was done so well and long ago with so many hits and still aint a sticky? wtf ive been around for a lil bit so luckily had seen it and could find it when i needed it.....(today), but newbies should be able to find this right away!
great writup zee. im working my way through my a.d.d. to get down the list but i think i need not go much farther then #1 so far!
COME ON MODS
STICKY!!!
Thanks for the kudos. This thread was added to the FAQ a month or so ago. It's ironic that I need to run the list myself, I've been having misfires. I guess I need to practice what I preach.
ZeeJay1997 is offline
post #137 of 440 Old 09-18-2013, 06:30 PM
AnotherRedZj
foot in mouth! guess i missed it while i was in there a cpl days ago.
damn a.d.d. again
AnotherRedZj is offline
post #138 of 440 Old 09-19-2013, 12:11 AM
Oldfrog
2007 WK
One other little tidbit that I may have failed to mention...and hope it helps someone else down the road..
I think I had bosch o2 sensors in mine before I swapped them the 2nd time. Not saying for sure that they were bad or shorted...because I simply replaced them without testing the sensors themselves. It would be ironic if shorted o2 sensors contributed to early PCM failure....but now I'll never know. Over 200 miles with the new pcm and not a single hiccup.
( and yes....my connector tabs are all broken off too...because some dumbazz
<<<<<<<<<<<<<<< did it.)
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #139 of 440 Old 09-19-2013, 02:00 PM
AnotherRedZj
I think I had bosch o2 sensors in mine before I swapped them the 2nd time. Not saying for sure that they were bad or sorted...because I simply replaced them without testing the sensors themselves. It would be ironic if shorted o2 sensors contributed to early PCM failure....but now I'll never know. Over 200 miles with the new pcm and not a single hiccup.
my O2 harness melted to my exhaust.....think it may have killed my pcm! Still diagnosing though.
If so where would you recomend getting a new pcm from? And what should I expect to give for one? I looked a lil but prices are all over the place.
post #140 of 440 Old 09-19-2013, 06:22 PM Thread Starter
ZeeJay1997
Be sure all the wires are separated.
post #141 of 440 Old 09-19-2013, 06:37 PM
AnotherRedZj
None of the wires themselves melted together, but the harness itself was squarely resting on the exhaust. Melted it enough that I had to break it apart. One wire was melted all the way through and exposed bare wire....wich WAS in contact with the exhaust.
post #142 of 440 Old 09-19-2013, 07:29 PM
Corrupt
Don't forget to mention that you get no CEL when you turn the key to on position, and your code reader won't connect to the PCM. Your PCM number is 05010384AB. On a side note, if he has to get another PCM for his Jeep; will he have to have it programmed by the dealer with his VIN?
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #143 of 440 Old 09-19-2013, 07:42 PM Thread Starter
ZeeJay1997
No, and neither will you
post #144 of 440 Old 09-20-2013, 01:29 AM
Oldfrog
2007 WK
My code reader would connect to the bad pcm....and like zeejay said, the 97 needs no additional programming prior to installation....not even mileage nor VIN.
When the downstream o2 sensor wires short, ( a common issue) they will most likely blow a 15 amp fuse in the PDC. Dont know what happens if the sensor develops a high resistance internal short.
Oldfrog is offline
post #145 of 440 Old 09-20-2013, 04:42 PM
Corrupt
I don't plan on having any issues with my PCM, but if I do, I'll keep that in mind.
Corrupt is offline
post #146 of 440 Old 09-20-2013, 05:05 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The words "plan" and "jeep" or "pcm" often do not travel well in the same sentence,lol.
Originally Posted by HighLonesome
coralman is offline
post #147 of 440 Old 09-20-2013, 05:32 PM
Corrupt
But issues, PCM, and Jeep go pretty good in the same sentence, Is that what you're saying?
Corrupt is offline
post #148 of 440 Old 09-21-2013, 01:55 AM
cgcarpenter
Finally got a code besides p0351.
Got P0320
So I'm going to replace my Crank position sensor. And if that doesn't work then PCM here I come.
Which crank sensor should I buy? Link would be great.
cgcarpenter is offline
post #149 of 440 Old 09-21-2013, 03:00 AM
Oldfrog
2007 WK
Why not test the crank sensor before laying out $80+ on it?
If it's bad, Mopar is the way to go.
Oldfrog is offline
post #150 of 440 Old 09-21-2013, 03:06 AM
Oldfrog
2007 WK
Now you've done it. You may have just jinxed your PCM.
They all fail eventually. I hope yours isnt next.
Poor quality is poor quality. Nothing we can do about it if we want to drive a ZJ.
If someone would ever come along and redesign the sensors, wiring and PCMs for the 96-98 models, I'd be his first customer....but it's not likely to happen 17 years later..
I have been thinking about mating an old chevy distributor, points, coil and carb with the 4.0, though.
( after I convert it to natural gas and solve the electronic tranny issue)
Oldfrog is offline
grounds , hesitation , no start , stalling , wiring
95 ZJ stalls? longtravel1 ZJ Grand Cherokee Forum 2 09-06-2011 10:12 PM
Stalls when low on gas. sk8tgk ZJ Grand Cherokee Forum 3 10-08-2010 12:34 PM
stalls toolman401 ZJ Grand Cherokee Forum 1 02-18-2010 06:19 PM
95 4.0 stalls when off the gas liredneck ZJ Grand Cherokee Forum 8 04-20-2009 06:45 PM
Please HELP my 95 Zj stalls wrestlerobx ZJ Grand Cherokee Forum 43 05-18-2008 08:58 PM
