110V block heater on 230V? - JeepForum.com
post #1 of 9 Old 01-13-2014, 04:16 AM Thread Starter
Berti
Hello,
I'm thinking about to start using the factory block heater, but because I live in Europe, only 230V is avilabe from the nework. Will the heater survive the higher voltage, as the excess heat will be dissipated by the coolant, or should I forget it to use it without the right transformator?
Thanks in advance!
Berti is offline
post #2 of 9 Old 01-13-2014, 05:07 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I would think not and will pretty quick about letting you know. Not a matter of dissipating heat, element will just fry. Same concept as trying to use a 110v household water heater in a 230 volt application, won't last long.
Originally Posted by HighLonesome
coralman is offline
post #3 of 9 Old 01-13-2014, 05:53 AM
shaban
You can also use some powerful diode to halve 220 volts, if you know what you are doing.
shaban is offline
post #4 of 9 Old 01-13-2014, 07:00 AM
Mickey_D
Just a lot easier/cheaper/safer to go have a 220V one installed. Since there's already one there, it quite simply is a matter of undoing one bolt, pulling the old heater, inserting new heater and tightening a bolt.
The hardest part is routing the power cord.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #5 of 9 Old 01-13-2014, 11:27 AM
CatSplat
1994 ZJ
I could have sworn there was a step in there that involved draining your coolant, though I suppose that as soon as you remove the heater it'll do that for you.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #6 of 9 Old 01-13-2014, 12:07 PM
Exdecuk
Just use a transformer builders use on site, they are cheap to buy. I use one on my 9er sometimes. Check this out:
http://www.ebay.co.uk/itm/Warrior-24...item27dd0989de
A man will pay $2 for a $1 item he needs.
A woman will pay $1 for a $2 item that she doesn't need but it's on sale.
Exdecuk is offline
post #7 of 9 Old 01-13-2014, 12:14 PM
Oldfrog
2007 WK
A voltage divider is built by using resistors.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #8 of 9 Old 01-13-2014, 12:45 PM
Timo_90xj
Timo_90xj's Avatar
Originally Posted by Berti View Post
Hello,
Thanks in advance!
Are you sure it is a 110V block heater? Unless the Jeep was imported from USA/ Canada, I'm pretty sure it has a 220/230V heater unit installed in it. All the Jeeps I've seen here with block heaters are 220/230V version.
***Under construction***
Timo_90xj is offline
post #9 of 9 Old 01-13-2014, 02:29 PM
Gearhead31
x2 unless the part (or the entire vehicle) was imported from the US/Canadian areas, chances are, it's 230v rated. I have to ask, how is it you believe it's 120v?
And to answer your question.. The extra voltage will burn up the unit, hopefully in a matter of seconds as to avoid possibly causing a fire. Your options are: 1- obtain a power converter, drop it from 230v down to 120v. 2- replace the unit to operate on your native power grids. 3- Plug it in as is and destroy at least the block heater.
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
