06 Jeep Liberty Wheels on a 1998 ZJ - Opinion? - JeepForum.com
post #1 of 19 Old 07-27-2011, 07:30 PM Thread Starter
iGotTheRunz
A co-worker has a set of 17" 2006 Jeep Liberty wheels. The bolt patterns match perfectly. I could run a 235/65/17 sized tire and be set.
Honest opinion - How do you think they'll look?
Mike
*The picture is just a sample but same wheel and same color.
iGotTheRunz is offline
post #2 of 19 Old 07-27-2011, 07:31 PM
gothchick
I'd have to see it on the ZJ with the offset... I threw a set of '05 Rubicon Moab wheels on my ZJ, and just lucked out that the offset worked.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #3 of 19 Old 07-27-2011, 07:32 PM
2doorxj
2doorxj's Avatar
I think itt would look nice, and it would also be original. I say do it!
2012 Cherokee of the Year
2doorxj is offline
post #4 of 19 Old 07-27-2011, 07:36 PM Thread Starter
iGotTheRunz
Had to use adapters though, right?
post #5 of 19 Old 07-27-2011, 07:37 PM Thread Starter
iGotTheRunz
I'm leaning towards it but want to see what everyone's opinion is. Or whether or not any one has seem a ZJ with these wheels.
Thanks for your input.
post #6 of 19 Old 07-27-2011, 07:38 PM
gothchick
No adapter needed for TJ wheels ('05 Rubi). You'll need them for JK wheels though.
post #7 of 19 Old 07-27-2011, 07:43 PM Thread Starter
iGotTheRunz
Oh, hard to find though. I like the look of that wheel much better.
post #8 of 19 Old 07-27-2011, 07:45 PM Thread Starter
iGotTheRunz
So... 2006 Jeep Liberty is:
5 lug 4.5 inch or 114.3mm High Positive Offset
I should have no issues, right? Bolt up and roll out?
post #9 of 19 Old 07-27-2011, 07:49 PM
gothchick
No problemo my friend. I'd just be a little worried that the Liberty wheels might be too skinny for bigger meat later down the road. What is the wheel width on those?
I got these wheels for $300 with factory GY MT/Rs. They're pretty cheap. Drove them for awhile then went to MTZ 33's.
post #10 of 19 Old 07-27-2011, 07:54 PM Thread Starter
iGotTheRunz
I got these wheels for $300 with factory GY MT/Rs. Drove them for awhile then went to MTZ 33's.
Wow - that is a sweet truck. Bigger meat as in larger tires? If so, I have no plans to go larger on tires. If I change my mind I would lift it and find the exact wheels you're rolling with.
So........ for now, I would stick with the 235/65/17 or whatever the biggest tire I could go without worrying about rub. Any suggestions?
Mike
post #11 of 19 Old 07-27-2011, 07:56 PM
gothchick
As long as the offset works, you'll be good to go~ :-)
31's are about the biggest you can go without lift...
post #12 of 19 Old 07-27-2011, 07:57 PM Thread Starter
iGotTheRunz
LMAO - Okay where it goes -- yes, it's embarrassing.
You keep referring to "offset" so what the heck does that mean?
Mike
post #13 of 19 Old 07-27-2011, 08:00 PM
gothchick
Offset is how far they stick out relative to the axle. Too little (-) offset and the wheels rub the undercarriage. Too much (+) offset and they stick out too far past the fender.
post #14 of 19 Old 07-27-2011, 08:06 PM Thread Starter
iGotTheRunz
So this is what I found doing a quick search on the Liberty forum:
17" (diameter) x 7.5" (wide)
Bolt pattern: 5 X 114.3mm (4.5")
Hub Center Bore: 71.5mm
Offset: +41mm.
Any ideas? I read about offset now. So it's the outside edge of the wheels distance from the center. Makes sense. So I need to ensure the wheel at least sticks out to the edge or over the wheel well.
Yeah?
post #15 of 19 Old 07-27-2011, 08:10 PM
gothchick
Yeah... Check this link out for offset calculator...
http://www.gtsparkplugs.com/WheelOffsetCalc.html
Opinion wanted on wheels vredenburg08 ZJ Grand Cherokee Forum 16 01-08-2009 11:02 AM
How do 18" Liberty wheels look and feel on a ZJ? Steven566 ZJ Grand Cherokee Forum 4 07-10-2008 07:33 PM
Wrangler Wheels on a 1998 Grand Cherokee Laredo Steven566 ZJ Grand Cherokee Forum 4 11-13-2006 01:21 PM
Wheels opinion ercrmr ZJ Grand Cherokee Forum 1 03-03-2005 10:42 PM
Will Liberty wheels fit? JCDubya ZJ Grand Cherokee Forum 2 01-15-2005 09:57 AM
