04 WJ SE 2" spring spacers tire size?
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
ex TJ 3" lift 33s
just got this 04 WJ few months ago.. wanned to go bit higher.. would love to fit 33s but I know it'll be b#$%^h .. so if I get these 2" spring spacers how big how wide tires I can fit with stock rims.. and would I have to change shocks control arms.. DS.. ? and if I choose to go with higher lift could I still add lift to these spacers I have? (trying to avoid cutting at all costs) Thanks
#2 |
I just got some 245/75/16 GY MTR to go with my 2" springs. Not on yet but it's a great combo all around.
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know |
#3 | |
I got P225/75/r16 that looks like theres not much clearance left at the front fender |
#4 |
245 is the tire width in millimeters, 75 is a aspect ratio for height (i.e. 75%) based of the width, 16 is the rim diameter. biggest u can fit will be a 265/70/16 (minor trimming might still rub at some extremes) or a little smaller like a 245/75/16 (no trimming or rubbing).
edit: 245mm = 9.6 inches 9.6 x .75 x 2 + 16 = 30.4" tires w x ratio x each side of rim + rim dia = total tire height
2000 Black WJ w/ I6, Selec-Trac | Tow-Hooks | Transfer Skid Plate | 2.5" KOR BB | SkyJacker 8000 Nitro Shocks | 245/75R16 Kelly Safari MSRs | 2 Eclipse amps | MB Quart 12" Sub | Phoenix Gold Speakers F/R | Pioneer MP3 Deck | |
#5 | |
#6 |
sounds good.. Thanks for the help.. !
#7 |
I had 265/70/16's when i had my 2" budget boost on. They're about 30.8x10.5
They only rubbed very lightly at full lock. You can get away with the stock control arms, shocks and definitely driveshafts at 2". I can give you a 9 month used set of Rustys hydraulic shocks for use with a 2" lift for free, just pay to ship them.
02 TJ. 2.5" RC Progressive Lift 1" PA Body Lift 33" KM's misc other stuff..... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
