04 WJ 4''Critical path driveshaft length (for Carolina DS) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 04 WJ 4''Critical path driveshaft length (for Carolina DS)
FS: Wranger BRIGHT License Plate LED! Just $3! Great valuePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-22-2009, 11:26 AM   #1
WJ04
Hey, Well I called Carolina DS today to see about getting Drive shaft for my front, But they need to know the length of the drive shaft at 4''. So I was hoping someone had measured their stock rezeppa-fixed yoke DS with a 4'' critical path, or if someone could for me. I guess you measure it from the TC side at 3 or 6 o'clock to center of u-joint on the diff side. also I have a 242 selectrac TC.
Thanks guys
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote Quick reply to this message
Unread 06-22-2009, 11:29 AM   #2
xJoshxx
2012 WK
yea i think you measure EAR TO EAR.
We will need a measurement for the length. Measure from either the flat machined mounting surface (face) which is just inside the pilot on the pinion flange or the lip of the flange to the face of the yoke on differential end..
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2
2012 WK2 SRT8
xJoshxx is offline   Reply With Quote Quick reply to this message
Unread 06-22-2009, 01:35 PM   #3
skain8
LEDs & Plasti Dip - WHY?
skain8's Avatar
Take your own measurement. Why take a chance with using someone else's? Takes all of 30 seconds.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
Half-Ton axle swap guide
231HD build info
skain8 is offline   Reply With Quote Quick reply to this message
Unread 06-22-2009, 02:58 PM   #4
WJ04
Yeah I think your right skain, if this rain ever lets up I'll take my own measurments to be sure.
Unread 06-22-2009, 03:41 PM   #5
skain8
skain8's Avatar
TW also has a good section on measurements in case you want to be 100% sure you're measuring correctly.
231HD build info
