04 Overland 4x4 Towing & MPG ?s - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 04 Overland 4x4 Towing & MPG ?s
Amsteel Blue Synthetic Winch line Free ShippingWarn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad
Unread 08-21-2008, 01:55 PM   #1
slush
I have a stock '04 Overland 4x4, owned it since 04, and still love it. It sees very little offroading as I use my Wrangler for most offroad adventures. However, I do tow with the Overland. I get 20-21MPG on the hwy, but as soon as hook up to a trailer (6’x12’ utility or enclosed 2,000pds loaded) my mileage drops automatically to 10-12MPG. If I run the trailer empty, I get 10 or less…but if weight is on it, I can get up to 11.7MPG.
What are others getting, with the same setup (4x4 Overland), when towing? Thanks.
slush is offline   Reply With Quote
Unread 08-21-2008, 06:36 PM   #2
GraKee99
Rapist Wit
GraKee99's Avatar
When I tow my boat (around 4700pds dry weight, normally more with gear) I get about 11mpg but I don't tow far and take it nice and easy. It is a tandem axle trailer which helps the mileage.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Unread 08-21-2008, 08:01 PM   #3
clgielin
2003 WJ
When I tow my YJ on a tandem 16', I get around 11 mpg also. Total weight is just shy of 6000 lbs. I would recommend trailer brakes on anything over ~1500 lbs.
*Edit* - I have 245/75R16 BFG mud terrains with stock gears.
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline   Reply With Quote
Unread 08-25-2008, 08:08 AM   #4
slush
Yep...it seems everyone is getting the same mileage, whether it is towing a light trailer (1500lbs or less) or a heavy load. Thanks for the responses, I was just wanting to ensure I wasn't the only one.
Unread 08-25-2008, 08:41 AM   #5
xmonger
2003 WJ
I get 11 mpg (city) without towing anything.
2003 WJ Overland 4.7 H.O.
1998 ZJ Laredo 4.0 - SOLD
xmonger is offline   Reply With Quote
Unread 08-25-2008, 04:53 PM   #6
slush
WOW! I thought our 15 mpg (city) was rough...because it went down from 17.5mpg (city) over the years.
Unread 08-25-2008, 07:25 PM   #7
jake97jeep
2003 WJ
I know a possible reason why it would have a significant drop... when you tow you should turn off overdrive which means you will be running at higher rpms, hence burning more gas. I think, I do not know for sure.
jake97jeep is offline   Reply With Quote
Unread 08-25-2008, 07:33 PM   #8
bradbb2005
Wow you have a heavy foot, even when i am horsing on my jeep i get like 12, but when i am towing i get like 11 and when on DD i get ~13 city and i can get up to 19 on the highway.
My Blog - A work in progress
Autocheck VIN Report for $5.00.
Originally Posted by Bubba3200 View Post
After I drain the oil I started the engine and ran it for a very short while..... to drain some oil out of the filter so it is not so messy.
Click Links to see Pics!
2001 WJ Laredo 4.7L V8
Mods:[]Cold Air Intake[]General Grabber AT2's 245/70-16[]1000W Inverter[]Flowmaster Super 44[]
2005 KJ Renegade 3.7 V6
Mods:[]Firestone Destination A/T's[]
bradbb2005 is offline   Reply With Quote
Unread 08-25-2008, 10:58 PM   #9
Redbob
Some of that loss (from 17.5 mpg) would be from the change to ethanol in the gas - close to a 5% drop, or 3/4 of an mpg for you.
Thank your Congresscritter for that little benefit...
Redbob is offline   Reply With Quote
Unread 08-26-2008, 09:04 AM   #10
xmonger
2003 WJ
Yes, she is new to me and I am breaking her in with a heavy foot.
Unread 08-26-2008, 10:00 AM   #11
Slummin
Why does that urban legend show up in every towing thread? You do NOT need to turn off the OD when towing. The ONLY time you should do so is if the transmission is hunting between gears. You SHOULD NOT turn off the OD for towing, unless you just enjoy buying extra fuel.
Slummin is offline   Reply With Quote
Unread 08-26-2008, 02:36 PM   #12
slush
I very rarely have to turn OD off...only in foot hills of the Smokey mtns so far. Every else I've towed our trailer it has been fine - transmission not hunting for gears
Unread 08-26-2008, 03:06 PM   #13
bradbb2005
I tow quite a bit and i always have to turn OD off i live in the adirondacks and the tranny hunts more than a redneck if i keep, it in OD, even while im not towing it shifts quite a bit, quite a bit of hill round' here.
Unread 08-29-2008, 12:29 PM   #14
mako
Junior Member
I believe the factory owners manual for my '02 HO says to turn off overdrive when towing heavy loads.
mako is offline   Reply With Quote
Unread 08-29-2008, 01:04 PM   #15
jake97jeep
2003 WJ
That is what my manual says for my '03 limited HO. That is why I posted it.
