04 Grand Cherokee - high idle, won't come down - JeepForum.com
post #1 of 9 Old 05-14-2005, 02:30 PM Thread Starter
04cherokee
Hi,
Just did a 30k service on my '04 but have a problem. I changed all 8 plugs along with oil, filters. While I had the black plastic intake off, I sprayed some throttle body cleaner on the intake and cleaned it up a bit. Started it up but the idle won't come down below 1,200 RPMS (it's fully warmed up). The CEL came on and the code/error was intermittent misfire, cyl #7. I reconnected the coil pack wire, turned off the light and it hasn't come back on. Seems like it's idling smooth but way too high. Any ideas what this might be ? I've looked around to make sure everything is hooked up and the throttle isn't stuck. I don't think this is related but I broke the vac line connection which goes into the oil fill/funnel piece. I used epoxy to fix it for now (or maybe permanent) and it seems fine. Any ideas appreciated !
Bob
04cherokee is offline
post #2 of 9 Old 05-15-2005, 07:22 AM Thread Starter
04cherokee
bump - does anyone know ? I'm stumped...
thanks for any/all help....
post #3 of 9 Old 05-15-2005, 08:14 AM
brandoncrone
You probably have a vacuum leak where you took the intake off....can I ask why you took it off?
Dodge/Chrysler/Jeep Technician 14 Years
ASE Master Certified
L1 Advanced Engine Performance
brandoncrone is offline
post #4 of 9 Old 05-15-2005, 08:33 AM Thread Starter
04cherokee
thanks for thr reply....
I think I used the wrong term when I said "manifold", what I meant was the plastic resonator which you have to take off to access the throttle body. I just took it for about a 5 mile drive and tried some WOT's to try and get it to reset.
No good, it won't idle at less than 1,800 RPM's. I have no CEL on. I removed the IAC and cleaned the plunger but that didn't help. If I unplug the IAC connector while it's running there's no change in the idle - is that normal or do I have a bad one ? If I do the same with the TPS, the idle changes so I think the TPS is good.
Aside from the idle, it's running great - good acceleration, smooth. I looked around for a vac line but the only one I disconnected was the big one on the drivers side of the resonator. I don't see any others disconnected. Is my IAC disconnect test a good one ? Could it have been damaged when I sprayed throttle body cleaner on the butterfly yestersday ?
thanks,
Bob
post #5 of 9 Old 05-15-2005, 08:57 AM Thread Starter
04cherokee
Brandon, if you have a few minutes and can call me...
I'm happy to pay for your time. I'm at 203-931-7513 (CT). Thanks !
Bob
post #6 of 9 Old 05-19-2005, 12:51 PM Thread Starter
04cherokee
Wierd coincidence or possible heads up
First, thanks to Brandon for trying to get a hold of me - much appreciated. Turns out the IAC was bad. It idled fine before I sprayed the throttle body so just a heads up if this happens to you. Maybe it was marginal and the cleaning put it over the edge, I don't know. New IAC and all is well...
Bob
post #7 of 9 Old 05-19-2005, 03:22 PM
brandoncrone
Very odd isn't it??? That would have been my suggestion to check if there were no vacuum leaks. Wouldn't have thought that would have been the problem being fairly new. We clean t-bodies all the time and have never run into that.
Such as life, huh?
Good day!
post #8 of 9 Old 05-28-2015, 04:53 PM
Adiazmio44
I overhauled 4.0. reassembled. started but idle takes off have to shut down check all vacuum lines cleaned thottle. everything i could think of. seems like i have pedal floored. anyone have any ideas
Adiazmio44 is offline
post #9 of 9 Old 05-28-2015, 05:31 PM
kg6mov
Hears the voices
kg6mov's Avatar
What jeep do you have? This thread is about a WJ (1998-2004 Grand Cherokee), since this thread was last posted in in 2005 the WJ and ZJ forums have split and this is now the ZJ (1993-2004 Grand Cherokee) forum.
If you have a WJ I would suggest posting in the wj forum here: http://www.jeepforum.com/forum/f310/
Either way, please give us more information on your jeep so we can help you.
kg6mov is online now
96 Grand Cherokee won't idle Kalei2418 ZJ Grand Cherokee Forum 15 06-12-2014 07:49 PM
03 Cherokee Overlander HO High Idle after tune up marciad32 ZJ Grand Cherokee Forum 2 05-31-2009 09:03 AM
High idle after replacing 4.0 with one from Cherokee skidmark421 ZJ Grand Cherokee Forum 8 04-08-2009 10:05 PM
02 Grand Cherokee High Idle at start magnumbp ZJ Grand Cherokee Forum 1 08-24-2007 06:26 AM
Idle RPM of 93ish Grand Cherokee? Azazal ZJ Grand Cherokee Forum 2 09-25-2006 09:14 AM
