'04 GC "Very small emissions leak" code
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Wifes '04 GC Laredo, bone stock 2wd 4.0 auto. CE Light came on a few weeks ago, I plugged the "diagnoser" in and got 2 codes that read something about "very small emissions/evap leak". I basically ignored them and turned them off, but it came on again this weekend. I plugged in again, and got the same codes. I'm thinking if its a "very small" vacuum leak then I may never find it. I was thinking it may be the gas cap (it's one of those OEM caps that "clicks" before it gets tight, so you really don't know how tight it is) but I doubt very seriously that I'd be that lucky. We haven't noticed any changes in fuel economy, power, etc... Any suggestions? Thanks for all input.
Jeep: A four-wheel drive vehicle of one-half- to one-and-one-half-ton capacity for reconnaissance or other army duty. A term applied to the bantam-cars, and occasionally to other motor vehicles (U.S.A.) in the Air Corps, the Link Trainer; in the armored forces, the ½-ton command vehicle. Also referred to as "any small plane, helicopter, or gadget." |
#2 |
tighten down the gas cap, make it click a few times. The code will be on there for a few start ups (probably about 8 start ups). Thats the first thing to check when you get that code.
1997 Jeep Cherokee, 4.0L, 30x9.50 Maxxis Bighorns, d-window wheels, cut fenders, chopped bumpers, flex-a-lite, flowmaster super 44 2003 Grand Cherokee Overland, 4.7L HO V8, 6000K HID's - SOLD IT 1996 Grand Cherokee Laredo, 5.2L V8, 3" Kolak exhaust w/ flowmaster 50 and magnaflow cat, K&N FIPK, 4300K HID's - SOLD IT My build thread http://www.myspace.com/HaleyChicoine http://www.facebook.com/home.php#/profile.php?id=1646857227&ref=profile |
#3 |
I've had this twice so far -- neither time was simply the gas cap.
Both times it was a pinhole leak in one of the lines near the gas tank. I couldn't locate it on my own, but that shop that did apparently used some smoke method.
'02 WJ: 4.7L, 5", 231HD w/SYE, 35's, Clayton's, locked, chopped & armor '06 XK: 65th Anniversary Edition '98 XJ: Stolen www.endlessmtnfab.com |
#4 | |
Most of the time that series of engine codes is tripped by a bad gas cap, so if your 2004 still has the OEM cap, it might be time for a replacement.
JF'er with a Theme Song Member #1 http://www.youtube.com/watch?v=MNzZzsvOClc His: 2009 Dodge Charger R/T- MOPAR CAI, vinyls by RiderGraphix, tinted windows, red painted calipers. 1986 Trans Am- Rebuild underway. Hers: 2003 Grand Cherokee Laredo-4.7 V-8, Leather, Power Everything, Factory Tow and Recovery Points, KOR 2.5" BB, RE Monotube Shocks, Maxxis Bighorns, Kolak 3" Exhaust. Gone, But Not Forgotten: 1994 Wrangler YJ- Too many mods, not enough money! |
#5 |
Maybe try switching brands of gas. It worked for me.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!! Utah Jeep Crew #8 FS: Rear wind deflectors || || Stock OEM Air Box Set Up
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
