04 GC hvac issues-blower motor and other issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 04 GC hvac issues-blower motor and other issues
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 09-02-2009, 09:14 PM   #1
nation1979
i have a 2004 GC limited.over the last 4 months since the outside temp has increased the a/c and other hvac functions havent beent working correctly.on really hot days the a/c will not work at all and when its cold the heater wont work.i have read a few threads with similar issues but havent really found a solution.is there a part i can replace or maybe just bypass?is there a name for the issue im having so i can search for it better?
nation1979 is offline   Reply With Quote
Unread 09-02-2009, 09:47 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Welcome to the forum.
Can you describe your problem a little better?
Is the air flow from the vents good or weak?
Is the temperature of the air not responding to the temperature controls?
When the heat does not work, is it both sides that do not work or is it just one side?
Wheelin98TJ is online now   Reply With Quote
