04 6 esn't always crank when key turned - JeepForum.com
post #1 of 2 Old 08-05-2009, 05:43 AM Thread Starter
georged
Doesn't always do it but every now and than when the key is turned to start there seems to be a slight click (can't really where sounds come from because of the stupid warning chime) but the starter does not turn. After two or three turns it catches and starts fine. First thing I am going to try is swap the starter relay with a similar one.
georged is offline
post #2 of 2 Old 08-05-2009, 01:28 PM
elmer_fud
are you sure the click isn't the starter spinning the gear into the flywheel and stopping?
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 08:34 PM
Oil Leak from Crank Pulley/Crank Seal? maderj ZJ Grand Cherokee Forum 10 01-16-2011 08:21 AM
Just turned over 100,000 on the overland. tigman ZJ Grand Cherokee Forum 2 10-24-2008 06:03 AM
Engine turned off xbucux ZJ Grand Cherokee Forum 1 06-18-2008 11:11 PM
Crank Crank Crank goes the engine skier123 ZJ Grand Cherokee Forum 3 12-04-2004 10:01 AM
