03wj 4"lift center to center upper and lower ca measurements? - JeepForum.com
post #1 of 2 Old 03-09-2010, 09:58 PM Thread Starter
ronsaun
2003 WJ
03wj 4" lift. does anyone have the center to center ADJUSTABLE upper and lower ca measurements ? i have the top bolt in on both the upper and lower and want to make sure i am centered in the wheel well when i am done. i know i can screw around with it all afternoon, but i would like to do it once! thanks again, ron
aussie rear end, drilled and slotted rotors, ceramic brake pads, ironman adj.front upper/lower and rear lower control arms, teraflex 4" spring lift, fat bobs 2' bb, rusty's drop pitman arm, jks adjustable trackbar, moog tie rod ends/ball joints, rancho 9000 shocks, kor dual stabilizer, rough country front and rear bump stop extensions, homebrew front quick disconnects, rough country rear swaybar link drop kit, IRO a-arm spacer, transfer case drop kit, homebrew rocksliders, rola roof rack, speed bleeders, 2" wheel spacers, 4-treadwright guard dog mt 265/75/16, mud flaps, superchip, k&n cold air intake, straightpiped, chrome tailpipe tip, v-led hid headlights w/halo, v-led hid foglights w/halo, kidde fire extinguisher w/bracket, maglite w/mounting bracket, cobra cb, firestik antenna, white gauges gauge face overlays, viair compressor, blue led interior lighting upgrade, hi lift 48" jack, hi lift jack base, wind deflectors for: hood, moon roof and windows, sony stereo, garmin nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, cobra radar detector, smittybilt gear seat covers and tailgate organizer, browning rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, addco rear swaybar, deer whistles, mobile one synthetic oil, slick 50 high mileage oil additive, k&n oil filter
TO DO:
reece front hitch, warn winch, elocker or arb front selectable locker, bulldog remote start, hi lift essential parts kit, 2-hella driving lights, gerry can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, addco front swaybar
ronsaun is offline
post #2 of 2 Old 03-09-2010, 09:59 PM
GraKee99
Rapist Wit
GraKee99's Avatar
This should be a good starting point but you may have to play around with it bit. Just part of doing it.
At 4.5-5" I have the following measurements on my front CA's and don't have any DW - very very minor bump steer so this is a good place to start off from (I have RE front & Teraflex rear control arms):
RE Front UCA: 16"
RE Front LCA: 17"
Teraflex Rear LCA: 18.5"
Brian
WJ, WK, CJ5
GraKee99 is offline
Command Center says "Rear Light Failure" RichB ZJ Grand Cherokee Forum 4 10-11-2009 09:06 PM
IRO 4.5" Kit Adj. Control Arms Center To Center Measurements? RrCoX22 ZJ Grand Cherokee Forum 8 04-02-2009 11:41 PM
"Relay Center" 1995 Grand Cherokee Phototaxis ZJ Grand Cherokee Forum 1 04-22-2008 08:48 AM
wj fender to hub center" merkur92 ZJ Grand Cherokee Forum 9 09-04-2007 07:37 PM
center lower vehicle display clock keeps reseting gbd8977 ZJ Grand Cherokee Forum 4 09-15-2003 05:43 PM
