03 wj howling over 25 and when turning. help!!! - JeepForum.com
post #1 of 9 Old 11-04-2009, 06:40 PM Thread Starter
ronsaun
2003 WJ
my wj howles from the passenger front wheel always when over 25mph and way worse when following S curves. what the h***? i replaced the wheel bearing the old one looked perfect. replaced the tire thought it was a slipped belt. there is no death wobble. the suspension(ball joints,tie rods etc. $1000 worth)(no brakes) 2000 miles ago. the howling is LOUD!!!!!!!! help
ronsaun is offline
post #2 of 9 Old 11-04-2009, 06:42 PM
gatorayde
Sounds like a CV joint.
gatorayde is offline
post #3 of 9 Old 11-04-2009, 06:49 PM Thread Starter
ronsaun
2003 WJ
can i do that myself and how much are the parts new/used?
ronsaun is offline
post #4 of 9 Old 11-04-2009, 06:51 PM
gatorayde
It's fairly simple:
JeepsLimited.com - D30 Axle Shaft/Wheel Bearing Removal and Replacement (WJ)
Most auto stores charge ~$100 or less after you bring back the old shaft.
post #5 of 9 Old 11-04-2009, 07:05 PM Thread Starter
ronsaun
2003 WJ
Originally Posted by gatorayde View Post
It's fairly simple:
i looked at the link. which part is the cv joint the one w/the rubber boot?
ronsaun is offline
post #6 of 9 Old 11-04-2009, 07:29 PM
gatorayde
Yes .
post #7 of 9 Old 11-04-2009, 07:34 PM Thread Starter
ronsaun
2003 WJ
Yes .
i will get the parts tomorrow. what would be the tell tale sign which makes you confident and why? thanks,
as always, ron
ronsaun is offline
post #8 of 9 Old 11-04-2009, 07:56 PM
gatorayde
The only things that would make a whinging noise at a consistant speed in that area are the wheel bearing and the CV joint. If you're sure it's coming from the passenger side, then it's more than likely the CV since you replaced the wheel bearing already.
If it sounds like it's coming from the front generally, then it could be a bearing in the diff.
Also, it could be a bad tire. Does it make the noise after you rotate the tires?
post #9 of 9 Old 11-04-2009, 08:09 PM
cirame1
hmm my bad cv's clicked on turns but no howling... could be ur dif. unless ur positive its the passenger side for sure.
98' 5.9 slate on slate...
3.5" F>R swap, front and rear adj. track bars
17" rubicons w/ 285 70 17 inch hankook mtr's
full 3 inch exhaust w/flowmaster 40 series
242j tcase swap completed by jeeps unlimited providence,R.I.
cirame1 is offline
Sparatic grinding/howling while turning?? Charlie's 99 ZJ Grand Cherokee Forum 4 10-07-2009 04:08 PM
44a howling Crasher ZJ Grand Cherokee Forum 0 05-21-2009 08:14 PM
Howling noise when turning the steering wheel at low speeds?! maxmk8 ZJ Grand Cherokee Forum 6 09-25-2008 09:54 AM
Howling Noise? ted13b ZJ Grand Cherokee Forum 7 05-14-2006 06:43 AM
Howling noise Borntobewildinn ZJ Grand Cherokee Forum 6 02-18-2006 02:30 PM
