03 GC Overland Leaking Power Steering - JeepForum.com
post #1 of 19 Old 05-26-2009, 08:04 AM Thread Starter
SDT03GCOverland
2003 WJ
Something on my Jeep's power steering system went out yesterday. Lots of fluid under the Jeep. I drove vehicle #2 to work today but I'll tear into this after work tonight. The fluid is pretty much everywhere underneath and all around the power steering pump so I can't tell where the leak is until I clean it off. I'm just wondering if there's a good starting place to look. Yeah.. hose couplings and whatnot, for sure, but being a member of this site, I was hoping some of you might have prior experience with a "Yeah x amount of people with that make and model have run into THIS..." type of answer.
Thanks in advance.
S.
SDT03GCOverland is offline
post #2 of 19 Old 05-26-2009, 08:38 AM
ZJPunk98
My father's 02 overland blew its powersteering pump last summer. Ended up replacing it because of the seals on the back of pump blew... I think.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #3 of 19 Old 05-26-2009, 09:45 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The high pressure power steering hose is a very common failure.
Its #8 in the picture below. Part # is 5019708AD.
Wheelin98TJ is offline
post #4 of 19 Old 05-26-2009, 11:01 AM
ZJPunk98
Attachment 74946
Now that you said that, i believe we replace/fixed leaking lines as well.
Erik
ZJPunk98 is offline
post #5 of 19 Old 05-26-2009, 11:02 AM
adamcorey
# 8 . that is correct.
2004 WJ. Limited. 4.7 H.0. fully loaded 255/75-17 BF Goodrich mud Terrains. K&N intake. Flowmaster dual side exit exhaust. Clarion door speakers with 12" pioneer sub. Rear flip down DVD with surround sound. 2.5 inch Rustys coils installed with 2 inch BB in the box waiting on extended sway bar links. Addco rear sway bar. Uniden CB. Viper 2 way alarm w/ dei start. It holds 5 guys with hunting and fishing gear and tows a 24 ft. Bass Tracker all at the same time.
1995 ZJ laredo 4.0 235/75-15 BF Goodrich all-terrains. K&N FIPK. Dynomax cat back. pioneer deck w/ 12'' bazooka sub(not the tube). rear integrated fog lights for night time surf fishing. roof and front bumper mounted rod holders. replaced--stock springs and shocks, alternator, starter, crankcase sensor, fuel filter, pads and rotors, front u-joints, thermostat, radiator hoses. tranny went so i traded it for the big boy above.
adamcorey is offline
post #6 of 19 Old 05-26-2009, 10:52 PM Thread Starter
SDT03GCOverland
2003 WJ
Thanks for the tips. I got hung up at work and did not have time to investigate tonight. I'll update later.
Thanks again.
S.
post #7 of 19 Old 05-27-2009, 09:06 AM
adamcorey
if it is # 8 please update where you find it and how much. i need one also.
post #8 of 19 Old 05-27-2009, 11:26 AM
Wheelin98TJ
JEEP FREAK
Its a dealer only part.
List price is $80.65.
You should be able to buy it for about $60 after discounts.
post #9 of 19 Old 05-27-2009, 12:36 PM
Diehard
Diehard's Avatar
Go to the vendor section here and give Avondale parts a request for a price. He isn't always the cheapest, but the other dealers may charge more for shipping and a handling charge. (Moparonlineparts: $53 for hose, but $12 for shipping and $5 handling charge and tax of course).
If it is that hose that is leaking the new one will have fitttings that look different, but it is the correct one. A little advice, attach top fitting first.
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker.
Diehard is offline
post #10 of 19 Old 05-29-2009, 02:06 PM Thread Starter
SDT03GCOverland
2003 WJ
OK... Finally got around to it. I sprayed all the gunk off with brake cleaner and blew it off using the compressor. I filled it with fluid and ran it cycling the stering wheel from lock to lock for under a minute. At the connection to the pump, on the hose-pump connection (#8 as pictured above) was clearly leaking. Although the nut is too tight to tighten any more, the section of pipe that comes out of the nut wiggles like a loose tooth. I don't understand, mechanically, what possibly went wrong here. I think I'll buy an open-end wrench that will fit on that better (such limited room to work) and see if I can't just snug it down a little. I just can't see how this can be leaking unless it somehow backed off a little and loosened up. At $80 (as suggested above) I'm not giving up just yet.
Stay tuned...
post #11 of 19 Old 05-29-2009, 02:16 PM
JForest2
It could be the fitting got worn out on the end of the hose.. I would replace that line anyway
James
JForest2 is offline
post #12 of 19 Old 05-29-2009, 02:29 PM
cherojeep
seems like mine is leaking by the #8 line where it goes into the pump. i washed it down and is wet around there. i think i made it worse the last time i was offroad cause now i got more of a drip and pump makes noise
2004 Jeep Grand Cherokee
2009 Honda Civic Si
cherojeep is offline
post #13 of 19 Old 05-29-2009, 02:39 PM
Wheelin98TJ
JEEP FREAK
Ya'll might as well give in and buy the hose from the dealer.
Those are tell-tale signs of the hose failing.
Its a problematic design. Jeep realized this and revised the part. The new part you buy will be slightly different.
post #14 of 19 Old 05-29-2009, 02:54 PM
MeWJWifeZJ
On my 2000 Limited, the actual steering gear let the pitman shaft seal go and dumped it's fluid all over my driveway.
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #15 of 19 Old 05-29-2009, 06:07 PM
Johannmn
I have an '01 WJ Limited with the same problem. How hard is it to replace this hose? Also I have read on the web that only dealer power steering fluid can be used due to a specific formulation. Is this true?
Johannmn is offline
Power steering box leaking colt808 ZJ Grand Cherokee Forum 1 12-14-2009 04:14 AM
02 GC Overland Power Steering Hose Replacement Tigerbass ZJ Grand Cherokee Forum 10 07-13-2008 04:28 AM
power steering leaking beckysjeep ZJ Grand Cherokee Forum 11 03-12-2008 07:20 PM
Help me with my leaking power steering hose frisco ZJ Grand Cherokee Forum 5 09-12-2006 06:05 PM
leaking power steering fluid adamsgrand ZJ Grand Cherokee Forum 9 06-21-2006 09:14 PM
