02 sensor - JeepForum.com
post #1 of 4 Old 06-27-2003, 11:02 AM Thread Starter
fut
02 sensor
What is a 02 sensor, my check engine comes on and the OBDII scan states a problem with the O2 sensor. Where is is located, and what exactly is it for?
This is not the oxygen sensor is it?
fut is offline
post #2 of 4 Old 07-02-2003, 12:52 AM
Colorado 5.9
Colorado 5.9's Avatar
Yes it the oxygen sensor . There are 2 of them one upstrean & one down stream passed the catalitic converter. Te up stream is the most important. The code should say which one. Get it replace as soon as you can. It can effect GAS milage & other things. I think if the up steam is bad, it can destroy your CAT. Replace it with ONLY a factory MOPAR OEM one. After market O2 sensors do not work very well in Grands.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #3 of 4 Old 07-02-2003, 03:13 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Fut,
to get more specific info, you might want to post this on the cherokee page and not the grand cherokee page. The cherokee guys have a ton of info for you.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 4 Old 07-03-2003, 09:56 AM Thread Starter
fut
Actually i own a cherokee, but the problem is with a "Grand" Cherokee.
fut is offline
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 10:22 AM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 12:01 AM
Bank 1 Sensor 2 '01 Grd Cher o2 sensor location mgrean ZJ Grand Cherokee Forum 15 02-06-2009 12:41 PM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 09:04 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
