'02 Grand Cherokee Lift - JeepForum.com
post #1 of 11 Old 08-24-2004, 02:51 PM Thread Starter
DRODE
2011 JK Wrangler
I just bought a 2002 Grand Cherokee and was wondering if any one has any experience putting a 2" Budget lift on and what kind of time and money would be involved.
DRODE is offline
post #2 of 11 Old 08-24-2004, 02:59 PM
+ d
+ d's Avatar
all you need to know... http://www.jeepsunlimited.com/forums...hreadid=388327
'04 4.0L 4x4 / 4" Hybrid lift, Bilstein 5150's (sans jks9602's), 255/70-16 BFG AT's, SD40, jks disco's, fipk, skids, hooks, kevin's sliders & an ECTED
+ d is offline
post #3 of 11 Old 08-24-2004, 09:02 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Wow, all in one place.
Now, will others read it or just blow you off?
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 11 Old 08-25-2004, 07:16 AM
Myrtle Beach
I paid about $130 for the BB and paid $100 for the install at a local tire shop. Alignment was $44 and tires were $500. I used the same shocks but if you have the $ it would be a good time to change them. My BB was made by Daystar.
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Myrtle Beach is offline
post #5 of 11 Old 08-25-2004, 10:32 AM Thread Starter
DRODE
2011 JK Wrangler
Thanks for the info
DRODE is offline
post #6 of 11 Old 08-25-2004, 12:30 PM
Clayton00grand
Do you rub with 265/75/16?
Clayton00grand is offline
post #7 of 11 Old 08-25-2004, 12:59 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Drode,
Pungo off-road is the best install place nearby. If you are interested in wheelin that Grand, look at www.nagca.com under Grand Slams and in particular Grand Slam East or GSE. They have a September ride coming up and then the huge ride next spring. There are several WJ Grands in your area.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #8 of 11 Old 08-25-2004, 01:31 PM
Myrtle Beach
My front tires rub a little bit when i turn in reverse. I will probably do some minor fender trimming on the bottom part of the front bumper where they rub. I mostly use my jeep for hwy driving but ocassionaly use it for off road. I did trim the plastic sheild in the wheel well where the tire also rubbed. They sure do look good though. I'll try to get some pics on the site soon.
post #9 of 11 Old 08-26-2004, 12:15 AM
Buddha_Kip
Buddha_Kip's Avatar
yes, you will rub with the 265/75/16's unless you - A) get wheel spacers (1/4" will do) for your factory wheels, or B) buy wheels with less than a 6" backspacing.
Here's where you'll rub in the front - stupid flap in the front that is easily cut off (like Myrtle did), and on the lower arms
pics -
In the rear, it really depends on the shocks you get...if you go with something like Rancho's where there is no "hard-boot", you'll only rub if you put those rubber dust boots on. If you go with a hard-booted shock (like ARB's OME long travels) you'll rub on the boot.
pics -
this is what you'll be sporting with 265/75/16's and a 2.5" lift -
Now you could go with a 235/85/16 tire which will be about an inch narrower than the 265's and will be about a tenth of an inch taller than them.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #10 of 11 Old 08-26-2004, 07:12 AM
Myrtle Beach
hey Buddha- Do your front tires rub the front bumper ?? I trimmed the flap but I still get minor rubbing when I am backing up. I noticed you have a 2.5" lift and I only have a 2" lift. Maybe that is part of my problem--
post #11 of 11 Old 08-26-2004, 11:39 AM
Buddha_Kip
Buddha_Kip's Avatar
no, they only rub that flap and even then, it is at full turn lock. probably the half an inch difference.
how can I lift my Grand Cherokee besides a suspension lift? 95jeepL ZJ Grand Cherokee Forum 18 09-15-2010 01:13 PM
01 Grand Cherokee Lift lamar2626 ZJ Grand Cherokee Forum 7 10-01-2008 06:48 AM
Grand Cherokee lift jeeper02 ZJ Grand Cherokee Forum 49 05-29-2007 10:20 PM
Any Lift kits to lift a 99 grand cherokee? Jeepfolk ZJ Grand Cherokee Forum 6 05-20-2007 10:54 PM
93 Grand Cherokee Lift dabandy ZJ Grand Cherokee Forum 2 08-18-2004 01:32 PM
