02 Grand Cherokee (4.7/auto/awd) just died...no juice at all - JeepForum.com
post #1 of 22 Old 04-05-2008, 07:39 PM Thread Starter
blue89bird
Earlier in the week when turning the key, nothing happened 2 times...third time it started right up without and problem and had been fine until just now
Driving to dinner....it just cut off...pushed it off to the side, dead as a doornail, no juice at all.
Any ideas or common things to look at?
Jason
2004 CTS-V Kooks Long Tubes, Corsa Exhaust, K&N FIPK, BMR T/A's and Ground Control coil overs 375rwhp, 1996 Jeep Cherokee, 1972 4-4-2 Convertible,1968 Camaro
blue89bird is offline
post #2 of 22 Old 04-06-2008, 06:09 AM Thread Starter
blue89bird
anyone????
Jason
post #3 of 22 Old 04-06-2008, 06:15 AM
mendelmax
Have you checked battery voltage?
I bet it is some relay dead. Now the question is which one.
By saying "dead" you mean nothing happens (no lights, no door locks, nothing?), or just that it doesn't crank?
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #4 of 22 Old 04-06-2008, 06:57 AM Thread Starter
blue89bird
no power whatsoever, no noises, no dash, no interior lights, no anything, it's like the battery isn't in the car, but it is, and it's got a plenty good charge on it.
Jason
post #5 of 22 Old 04-06-2008, 06:59 AM Thread Starter
blue89bird
I guess my question is, where are all of the places that have the ability to just cut all power to the car,
fusible link?
fuse/relay?
ignition switch?
Jason
post #6 of 22 Old 04-06-2008, 07:17 AM
mendelmax
All main relays and fuses are located near the battery in the fuse box, none of the internal ones can cause absolute power loss. There is an IOD fuse that if I remember right may cause this sort of problem. I would check this one first.
post #7 of 22 Old 04-06-2008, 10:22 AM
Neongirl4ever
Dont forget to check all connections to make sure they are clean.
2002 Black WJ 4.7L H.O
Quadra Drive
Is repairing considered a modification?
Neongirl4ever is offline
post #8 of 22 Old 04-06-2008, 12:29 PM
CMARJEEP
CMARJEEP's Avatar
if you have another key try using it. if there is a key on the top right of the instrument cluster that is flashing yellow with a cross through it then the sentry key has gone bad.
CMARJEEP is offline
post #9 of 22 Old 04-06-2008, 02:01 PM Thread Starter
blue89bird
went over to where we left it last night - still dead as a doornail. Call a tow truck, get it towed to the shop - started right up.
Jason
post #10 of 22 Old 04-06-2008, 02:47 PM
mendelmax
So it is some loose connection- transport caused some vibes that connected it.
Then you have a lot of work with taking every plug, fuse and relay out, cleaning it, and putting together. That sucks... But on the other hand it may be cheap to do.
post #11 of 22 Old 04-06-2008, 03:05 PM
dcvance87
I was going to suggest the "Auto shutoff relay" to be replaced but since its a total power loss I'd say....Good luck. definitely a loose connection somewhere. Next time you get it running start tugging on wires under the hood, etc. and see where it gives out at. When it shuts off you found your culprit.
06' TJ, 4" Rough Country lift, 2" body lift, 35 BFG all-terrains.
dcvance87 is offline
post #12 of 22 Old 04-06-2008, 07:31 PM Thread Starter
blue89bird
left it at the shop so they can still look at it, but nothing looks loose at all.
I tugged on every wiring harness I could and nothing made a difference.
Pulled every fuse and relay (both inside and next to the battery) everything looked good as well.
Jason
post #13 of 22 Old 04-06-2008, 08:04 PM
CMARJEEP
CMARJEEP's Avatar
did you try the key???
CMARJEEP is offline
post #14 of 22 Old 04-06-2008, 08:10 PM
speedbullet2
I had a car that did this was the battery terminals needed cleaned i wasted 60 bucks on a tow too what a goof
1996 Jeep ZJ Orvis Edition 5.2L Completely stock with Up Country suspension.
2.25" BB soon to be installed.
_______________________________________________
FUTURE MODS
Trailready front and rear bumpers with winch. Roof rack. KOR light bar with 4 lights. 2 lights, shovel, and a high lift jack mounted to roof rack.
speedbullet2 is offline
post #15 of 22 Old 04-06-2008, 08:14 PM Thread Starter
blue89bird
yup, have 3 of them, all did the same thing
Jason
99 Grand Cherokee Died today... Help twmart ZJ Grand Cherokee Forum 9 03-26-2017 10:43 AM
2008 Grand Cherokee Died suddenly JohnDeerCJ WK Grand Cherokee & XK Commander Forum 6 07-08-2009 06:19 PM
no juice to radio 97 grand cherokee austtill ZJ Grand Cherokee Forum 2 02-18-2009 11:35 AM
93 grand cherokee just died my94cherokee ZJ Grand Cherokee Forum 3 09-04-2006 09:15 PM
grand cherokee died freeburg ZJ Grand Cherokee Forum 4 11-29-2005 08:28 PM
