02 GC Laredo/oil pressure problem
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Thru all my searching on this it sounds like a sensor, Hopefully anyway! Do any of you know where this sensor/sending unit is located at and here I go again - Can a girl replace this?
Any little tips would be appreciated.
#2 |
what engine?
#3 |
Hmmm. V8 help
#4 |
You posted in the wrong section
Have you tried to pull codes ? Turn the key on and off 3 times and watch the odometer for codes.
Nickerdoodle 03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's 35" BFGoodrich KM2 sira4x4.net North East Offroad Club www.carolinadriveline.com www.ironrockoffroad.com kolak@aol.com |
#5 |
Don't know anything about the codes. What section should I have posted in?
#6 |
Mr. Hyde!
Moved to the ZJ/WJ section
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#7 |
ok thanks.
#8 | |
I bought mine from the dealer for $45 if I remember right. Part number is 56028807AB. You can buy it from a Dodge dealer if your local Jeep dealer doesn’t have one. |
#9 |
My oil pressure sending unit bit the dust about two weeks ago. I picked mine up at Autozone for $47 with a warranty. I removed the oil filter to get better access to the sensor. You will have to disconnect the electrical connection on the sensor before you can get a socket on it. I was able to get away with a deep well 1-1/16" Socket. (actually I got the sensor from the parts counter and took it over to the sockets on the shelf and grabbed the deepest one that I could find that fit the socket). The hardest part for me was getting the electrical connection apart. On the connection there is a red tab that locks the connection together. You must slide it to one side and to be able to pull it apart. If you need to get a better look at that style of connection they are used all over under the hood. I checked out one over on the passenger side up by the firewall. Also it helped me to spray a little WD 40 on the connection prior to pulling it apart.
Dont make me take my top off. |
#10 |
Got the part at OReilly's $37. Then it got really cold here. Took to a local shop and they put my part on for $44. Then found something leaking, thought it was oil. Took it back and they said it's not oil. My power steering pump is leaking and 2 leaks in the transmission! the sending unit for the oil prssure worked great tho.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
