01 Wj 4.7L trans problems - JeepForum.com
post #1 of 11 Old 09-18-2009, 11:52 PM Thread Starter
92wrangler
Hey guys recently my jeeps trans started acting up. It shifts fine from 1st to 2nd and drives fine but anytime you put the trans selector into D it acts like it's in neutral. Has anyone else had this problem and what is the fix. Like i said it shifts from 1st to 2nd perfectly fine it's only when in D that it acts like its in neutral and slips.
thanks for any advice...
Jason
2001 Grand Cherokee Limited v8 4.7L H.O Black, leather, fully loaded, tinted windows all the way around
1997 camaro Z28 Fully forged 355, Stage 3 heads, Gm847 cam, Nitrous,
92wrangler is offline
post #2 of 11 Old 09-19-2009, 05:49 AM
Turbonut
Changed the 2 filters and used ATF+4 lately?
Turbonut is offline
post #3 of 11 Old 09-19-2009, 06:50 AM
rm2001wj
rm2001wj's Avatar
There are a large number of transmission diagnostic trouble codes that don't turn on the MIL. Check for codes which might indicate something to fix.
rm2001wj is offline
post #4 of 11 Old 09-19-2009, 08:19 AM Thread Starter
92wrangler
I have receipts from the previous owners saying it was one at 45k or so the jeep just broke 80k now. Thanks i'll cycle the key and see if there is any codes.
post #5 of 11 Old 09-19-2009, 05:51 PM Thread Starter
92wrangler
ok so i replaced both speed sensors and same thing what would be the next thing i may check for.
post #6 of 11 Old 09-21-2009, 10:54 AM
Double E
Double E's Avatar
Acts like it is in neutral..... It does not move?
How is reverse?
How is your fluid level?
Filters & fluid new?
Got any leaks?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is online now
post #7 of 11 Old 09-21-2009, 11:02 AM
rm2001wj
rm2001wj's Avatar
There are trouble codes for faulty speed sensors. Are you replacing parts without first retrieving codes????
rm2001wj is offline
post #8 of 11 Old 09-24-2009, 09:52 PM Thread Starter
92wrangler
hey guys finally figured out the problem apparently there was a TSB about the valve body bolts being weak and blowing apart. Jeep sells a kit for $110 comes with new bolts new gasket and a new screen, While i was in there i did a fluid flush and also replaced the filters. The jeep seems to shift fine now and haven't had any other issues with the trans yet so hopefully its fixed.
Jason
post #9 of 11 Old 09-25-2009, 06:41 AM
Double E
Double E's Avatar
Thanks for the update.
These guys did a fix for that issue and a nice write up. Should it happen to me, I'll upgrade that part.
5-45RFE Fluid Change/TransGo Shift Kit Installation - North American Grand Cherokee Association
This repair doesn't look too insane to tackle on a Saturday.
post #10 of 11 Old 09-25-2009, 06:50 AM
gman1322
gman1322's Avatar
I did it a couple of months ago. Not really difficult, more messy than anything. The shift kit comes with a stiffer plate to put on there. Make sure you torque those torx bolts properly and use a little lock-tite. Oh, and I put a PML deep pan on there too so I had a drain plug for next time! Make sure you follow the instructions on the shift kit and be careful installing the filter seal in the pump. Soldering the resister was a pain in the *** but doable.
gman
2008 Jeep Liberty Sport
- 3.5" Rock Krawler, 245 75 16E Treadwright Warden AT's, Jet Stage One Chip
2007 Dodge Ram 1500 4WD
- Superchips 3865, 305 55 20 Nitto Grappler MT's, Hellwig sway bar, Powerwire, Sonnax Line Pressure booster, Bilstein Leveling Kit and rear shocks
gman1322 is offline
post #11 of 11 Old 09-25-2009, 01:15 PM
Grdaemon
Grdaemon's Avatar
Can anyone describe the two filters..?? I never knew there was a tranny filter..
X-Cherokee 1991 Limited Hunter Green
Now 1999 WJ Limited 4.7
Bright Platinum Metalic Clear
Grdaemon is offline
99 WJ trans problems with codes. Help bluegrassz ZJ Grand Cherokee Forum 1 08-26-2009 06:18 AM
trans shifting (some problems) grand-limit ZJ Grand Cherokee Forum 6 05-17-2009 09:00 PM
97 GC 4.0 L trans problems- help please! whiteltone ZJ Grand Cherokee Forum 2 12-04-2006 05:52 AM
Trans problems again. hanly2 ZJ Grand Cherokee Forum 9 09-19-2006 01:33 PM
Few questions about 99 GC..trans problems? Black99Grand ZJ Grand Cherokee Forum 5 08-17-2004 07:56 AM
