'01 Grand - A/C Question-Low Pressure Cut - Off Switch - JeepForum.com
post #1 of 6 Old 07-30-2009, 02:04 PM Thread Starter
CheapSunglasses
2007 XK Commander
'01 Grand - A/C Question - Low Pressure Cut-Off Switch
My wife's '01 Grand's A/C needs a charge and the low pressure cut off switch is preventing the compressor from coming on.
Can anyone tell me where the switch is, and how do I jump it to allow me to re-charge the system.
Thanks
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #2 of 6 Old 07-30-2009, 02:27 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Just jump the ac compressor clutch and recharge. Its right there and easy to get to.
WiCkeDuDe is offline
post #3 of 6 Old 07-30-2009, 02:36 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
So, its completely empty? Otherwise you wouldn't need to jump it to charge it. If it is completely empty, you will need to find and fix the leak or you will be charging it constantly.
~James
ezflip is offline
post #4 of 6 Old 07-30-2009, 02:42 PM Thread Starter
CheapSunglasses
2007 XK Commander
How exactly do I jump it? I just don't want to fry anything.
Yeah it's completely empty....It seems to be a very small leak, so I bought the sealer and recharge kit....I figured I'd give it a shot before spending money.
post #5 of 6 Old 07-30-2009, 05:44 PM
WiCkeDuDe
WiCkeDuDe's Avatar
The AC compressor clutch will have a 2 pin connection to it. It simply uses 12volts and a ground to engage the clutch. Just jumper 12 volts and a ground to it and start the recharge.
post #6 of 6 Old 07-30-2009, 07:17 PM Thread Starter
CheapSunglasses
2007 XK Commander
I ended up finding the low pressure switch and jumping the harness side with a paper clip to override the low pressure cut off switch and trick the clutch into engaging.
Thanks all
Oil Pressure Switch Location....95 ZJ, 5.2L AFMarksman ZJ Grand Cherokee Forum 6 12-27-2009 09:05 PM
What does the oil pressure switch do... 99avant ZJ Grand Cherokee Forum 2 06-24-2008 06:35 AM
Oil Pressure Switch? mpitcher ZJ Grand Cherokee Forum 12 04-10-2007 01:01 PM
Oil Pressure Switch nccherokee ZJ Grand Cherokee Forum 2 03-25-2007 06:30 PM
&$%(*#@ Oil Pressure Switch! dpierson ZJ Grand Cherokee Forum 17 06-11-2006 10:43 PM
