00WJ fuse #20 - JeepForum.com
post #1 of 4 Old 11-03-2009, 04:31 PM Thread Starter
BLKGRANDJP
00WJ fuse #20
WJ keeps blowing the number #20 fuse. It only happens when you shift from reverse to Drive. Then the fuse blows and you lose the turnsignals and blower. If you start the jeep in neutral and shift into drive the fuse won't blow. I figure it has to be something with the backup lights,or NSS. Does not happen by just hitting the brakes. Any ideas?
00 WJ 4.7L
99 XJ 4.0L
89 Wrongler
BLKGRANDJP is offline
post #2 of 4 Old 11-03-2009, 06:25 PM
rm2001wj
rm2001wj's Avatar
Yeah, that fuse passes current that goes through the transmission solenoid/TRS assembly and on to the back-up lights. If there is a short in the part of back-up lights circuit going from the solenoid/TRS connector to the lights, you might have a chance of finding it. If there is a problem with the solenoid/TRS assembly, then you will need professional help.
It would be a good idea to check and retrieve any diagnostic trouble codes stored in the PCM.
rm2001wj is offline
post #3 of 4 Old 11-05-2009, 10:47 AM Thread Starter
BLKGRANDJP
codes 1784 in TCM. Not sure what this means
00 WJ 4.7L
99 XJ 4.0L
89 Wrongler
post #4 of 4 Old 11-05-2009, 11:23 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
are you sure thats the code?
I dont see it here Jeep Grand Cherokee WJ - Diagnostic Trouble Codes
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
00WJ 4.7 with a Knock tsc ZJ Grand Cherokee Forum 37 02-21-2009 09:11 AM
00WJ lift parts needed? 3rd-go-around ZJ Grand Cherokee Forum 2 01-26-2009 09:54 AM
where's the fuse jeepster2000 ZJ Grand Cherokee Forum 0 01-08-2008 12:44 PM
How much for 00WJ Othoni ZJ Grand Cherokee Forum 1 03-01-2005 10:44 PM
Fuse Box jrcaz7 ZJ Grand Cherokee Forum 1 05-23-2004 11:14 AM
