'00 Jeep Grand Cherokee Engine Knocking after changing oil - JeepForum.com
post #1 of 24 Old 04-08-2009, 04:46 PM Thread Starter
depebush
I have a 2000 Grand Cherokee and i had gone probably 9000 miles between oil changes and now I changed the oil and its knocking, I think its a top knocking, there is not water on the oil, or metal shavings in the oil either but not sure if it may be a lifter or a rod?
depebush is offline
post #2 of 24 Old 04-08-2009, 04:52 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Let me guess is it a 4.0?
Do you have the proper amount of oil in it? If everything seems ok, and it is just making a slight knocking don't worry its a common symptom of wear in a 4.0 - The lifters tick.
if it goes away at revs above idle then I wouldn't worry too much. Its not catastrophic, just keep changing the oil.
WALTER
walter_da_jpr is offline
post #3 of 24 Old 04-08-2009, 04:55 PM
dougy147
Ticking.....4.0......bring on the Lucas oil stabilizer!
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #4 of 24 Old 04-08-2009, 04:57 PM Thread Starter
depebush
i put 5 quarts of oil, it started as a ticking but now its a knocking and wont go away while the car is in motion it goes along with the RPM's but the oil pressure is normal
depebush is offline
post #5 of 24 Old 04-08-2009, 04:59 PM Thread Starter
depebush
there is no power loss though
depebush is offline
post #6 of 24 Old 04-08-2009, 05:04 PM
the88thpianoman
2003 WJ
4.0 takes six quarts of oil.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #7 of 24 Old 04-08-2009, 05:06 PM
98zjdave
Do you have a 4.0L? I know my 4.0L takes 6 quarts.
98zjdave is offline
post #8 of 24 Old 04-08-2009, 05:09 PM Thread Starter
depebush
so if its short a quart will it knock ?
depebush is offline
post #9 of 24 Old 04-08-2009, 05:11 PM
DaveMurray
Even if it wasn't the lack of oil causing the knocking, why wouldn't you fill the oil to the FULL line?
You know what I love about my Jeep? It's 2WD. And that totally confuses people. "You mean they sold 2WD Jeeps?" Which in Canada they didn't. The look on their faces makes my day.
DaveMurray is offline
post #10 of 24 Old 04-08-2009, 05:15 PM Thread Starter
depebush
i thought it was gonna be enough
depebush is offline
post #11 of 24 Old 04-08-2009, 05:32 PM
98zjdave
You should always fill it up all the way, running low a quart of oil isnt the worse thing you can do, but lets just say its not the best either. Fill that last quart up with a quart of lucas and go from there.
98zjdave is offline
post #12 of 24 Old 04-08-2009, 05:39 PM
walter_da_jpr
From my own personal experience 5.5-5.75 quarts is the magic number. Remember that some oil stays in the crankcase.
I usually fill it to 5.5, drive it, let it sit for a bit, then read the dip stick and bring it to full. It never takes 6 to fill it.
Just dumping in 6 is not necessary and IMO not worth the risk of overfilling even slightly.
Also being down roughly 1 qt should not cause knocking.
WALTER
post #13 of 24 Old 04-08-2009, 06:59 PM
dougy147
With the 4.0s I had and my 4.7 I dump in the 5 quart jug and then 1/4 to 1/2 of the 6th quart, start and let idle for a few minutes and recheck.
I always ran Lucas in my ZJ after 120k or so. I would use almost a quart in the summer, and about 1/2 in the winter. That helped a lot. I would also advise against a certain orange filter, that happens to have FRAM painted on the side In my very limited experiences with them on a 4.0 the anti-drainback valve or whatever you want to call it was less than adequate
Oh, and since I don't think it's been mentioned....9k is probably a little long if your not running synthetic.
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
post #14 of 24 Old 04-08-2009, 07:13 PM
gatorayde
9k intervals and a quart low, awesome maintenance (not). It could be a typical 4.0 or it may be on it's way out (which I wouldn't doubt).
gatorayde is offline
post #15 of 24 Old 04-08-2009, 08:15 PM Thread Starter
depebush
well I added another quart still no improvement so I dont know it may be a lifter or a rod , how much longer do i have til it gets really bad
depebush is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
97 Jeep Grand Cherokee engine code 43 cody11ca ZJ Grand Cherokee Forum 9 10-14-2013 01:11 PM
94' Grand Cherokee Knocking and Stumbling Navalynt ZJ Grand Cherokee Forum 2 01-21-2011 08:57 PM
Oil engine Castrol Edge is ok for Jeep Grand Cherokee WJ engine 3.1 VM Motori ? diogene ZJ Grand Cherokee Forum 0 11-11-2008 02:51 AM
knocking noise from back of 2004 grand cherokee daveleonard21 WJ Grand Cherokee Forum 2 03-09-2004 11:47 PM
