00 GC stalled and won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 00 GC stalled and won't start
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-11-2008, 11:36 PM   #1
mattpm07
2000 Grand Cherokee w/ the 4.7l and 2wd. Going down the road today and just cut out. It turns over for about 3 seconds till it acts like it catches but it only catches for about half a second until it dies. When the key is on and all the gauge lights come on, then go off, Check Gauges light stays on. I tried messing with the pcm and such. I had it towed to a local shop to have them run the code and run the diagnostics on it. I'm leading to believe it's the Crankshaft Position Sensor. Anyone else have experience with this problem. It's like the timing or something is way off for the half second it wants to start. The fuel pump turns on when it's cranked so we're good there also.
Matt
mattpm07 is offline   Reply With Quote Quick reply to this message
Unread 02-12-2008, 07:47 AM   #2
mattpm07
BTT anyone?
Unread 02-12-2008, 09:04 AM   #3
00RedWJ
2006 WK
I had similar symptoms and it turned out to be the Camshaft Position Sensor
2000 Red Grand Cherokee Laredo WJ
4.0 with Selec-trac
Sold 1-2013
2006 Black Grand Cherokee Laredo WK
3.7 with 65,000 Miles
00RedWJ is offline   Reply With Quote Quick reply to this message
Unread 02-12-2008, 01:47 PM   #4
AgitatedPancake
I had the same exact problem. I had no spark or anything. Replaced camshaft position sensor and crankshaft position sensor at the same time and no more problem.
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 08-07-2009, 05:40 PM   #5
krossfyah
where is the cam shaft position sensor locationed on the JGC 4.7? could not find it
krossfyah is offline   Reply With Quote Quick reply to this message
