0 oil pressure and no check engine light? Also what trigers major check engine fault - JeepForum.com
post #1 of 10 Old 01-06-2007, 11:34 PM Thread Starter
SPL Tech
I have two questions. First of all what things will trigger a major check engine fault (check engine light flashes)?
Also once I accidentally broke off my oil pressure sensor and the oil pressure gauge dropped to 0. Well the check engine light did not come on. Why not? I would think no oil pressure would trip a major check engine fault (light flashes).
SPL Tech is offline
post #2 of 10 Old 01-06-2007, 11:42 PM
gunthagunth
gunthagunth's Avatar
Yeah its weird. The oil pressure doesnt affect the CEL or even a check gauges light.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #3 of 10 Old 01-06-2007, 11:44 PM
-Joe-
-Joe-'s Avatar
Several things will cause a check engine light.. They are listed on here somewhere, or in a haynes or chiltons book.
The oil pressure sender only sends the pressure to the gauge, nothing else. The pcm doesnt monitor the oil pressure.
edit..
not sure if newer years have a "Check Gauge" light or not.. But that would alert you to a low oil pressure..
My zj only has the "Check Engine" light
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 10 Old 01-06-2007, 11:45 PM Thread Starter
SPL Tech
Hmmm... So a loose gas cap warrants a check engine light, but not no oil pressure. lamo. I think some of the engineers at Jeep like to sleep on the job sometimes.
SPL Tech is offline
post #5 of 10 Old 01-06-2007, 11:51 PM Thread Starter
SPL Tech
edit..
I know there are several things that can fault the check engine light. But there are less then 10 that will trigger a severe fault (light flashes). btw.. I am talking about the 1994 ZJ with the 4.0
SPL Tech is offline
post #6 of 10 Old 01-06-2007, 11:53 PM Thread Starter
SPL Tech
And the search option is not working. It never really has.
SPL Tech is offline
post #7 of 10 Old 01-06-2007, 11:54 PM
-Joe-
-Joe-'s Avatar
I keep forgetting if you dont donate you dont get the search option.. sorry.
- Joe -
-Joe- is offline
post #8 of 10 Old 01-07-2007, 09:02 PM Thread Starter
SPL Tech
oh. so anyone know what will trigger a high level echeck engine fault?
SPL Tech is offline
post #9 of 10 Old 01-07-2007, 09:12 PM
greasefingers
greasefingers's Avatar
1994 ZJ
I think we are talking about two different things?
The oil level sensor is located on the passenger side of the oil pan. It will light a lamp only when a low level is sensed or trouble with the wiring.
The dashboard oil pressure gage is reading the pressure sensed at the oil filter. It is not tied into any warning lamps, as someone has already stated.
If I remember correctly, a flashing Check Engine light is a warning. If it is steadily lit, then this is a more serious issue?? I will try to find out where I read that.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #10 of 10 Old 01-08-2007, 07:28 AM
sgarlic
That's only true of some years and models. My '96 has a check gauges light that illuminates when that needle drops to zero.
If it's flashing, it's a misfire condition, if it's steady, it's a stored PCM trouble code.
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
Power Washed Engine - Check Engine Light on Now Davis87YJ ZJ Grand Cherokee Forum 31 08-11-2008 08:17 AM
Q: Fault Code P0720 - check engine light johnbnguyen ZJ Grand Cherokee Forum 0 11-15-2005 10:24 PM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 01:49 PM
