I have what was an soa kit I bought for a mj 44 (small axle tubes) and never used, only thing that makes it not a complete kit is I used the shock mounts. I have the u bolts, nuts, washers and plates and spring perches. I set my 44 up sua and bought the kit thinking I could use it but it didn't work out for me (would of lost lift/ ground clearance) so I just bought some other perches and used those. This could also be used for a dana 35 as the axle tube diameter is almost identical. Nothing wrong with the parts other than a little surface rust from being in a box of parts in my garage for 2 years. Hopefully someone else can use them.
