Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE
Best place to buy Rubicon Express! Don't Fear the Jeeper!Insane Rough Country Deals Call for more Info!!! so insanBarnes 4WD Universal 4 Link Kit
Go Back   JeepForum.com > Four Wheeling Forums > Jeep Clubs > Colorado Jeep Club
Jeep Registry Register Blogs FAQ Mark Forums Read Search Members
Old 05-17-2009, 01:45 PM   #1
James750
1990 MJ Comanche
Twin Cone: Sunday the 31st?
I want to hit up Twin Cone on Sunday the 31st.
Meeting Place is Conifer Staples at 9:00am.
1990 mj,
Colorado Jeep Club #178
Originally Posted by Ubie View Post
Three words: Flying Spaghetti Monster
Originally Posted by War Eagle View Post
Praise be unto His Noodly Appendage.
James750 is offline   Reply With Quote
Old 05-17-2009, 09:28 PM   #2
froggo27
i might be down for it.
Kamil
Colorado Club Member # 53
04 WJ Limited
My Trail Pics!!
froggo27 is offline   Reply With Quote
Old 05-25-2009, 12:34 PM   #3
James750
1990 MJ Comanche
Is there any interest?
1990 mj,
Old 05-25-2009, 02:31 PM   #4
otisdog
I might if it's open. I don't know how far one can get. Haven't heard any info yet.
Jim
03 Sport
otisdog is offline   Reply With Quote
Old 05-25-2009, 07:33 PM   #5
CLNinja
The Other Matt
CLNinja's Avatar
if i get my motor mounts finished and my rear axle shaft done before then i would love to come
Matt
**September 2009 Grand Cherokee Of The Month**
Colorado Jeep Club Member #88
CLNinja is offline   Reply With Quote
Old 05-25-2009, 07:49 PM   #6
James750
1990 MJ Comanche
Sounds good Matt, I do need to call the forest service to double check that it is open, I think it should be. I also need to get a new tapered sleeve for my currie adjustable trackbar. About a month ago I had the mounting bracket go bad and it had some play causing DW and a bad clunking noise. It came back this week and i pulled the trackbar off and the tapered sleeve was broken in half. I'm hoping that is what was causing my DW this time and not another broken mounting bracket. I will have to see. Either way, it will be fixed by this weekend.
1990 mj,
Old 05-26-2009, 12:45 PM   #7
XJimmy
Can I go?
I'd like to go. If you guys wouldnt mind.
My XJ is pretty capable but it is limited right now with open/open diffs, and no front recovery point, winch bumper or winch. I also only have a stock size spare, I do however have a small air compressor and tire repair kit so which ever works in an event I need to use one or the other... what ever gets me back down.
So let me know. I will be with my girl and 2 kids (6yr olds)... This will be only our 2nd time wheeling.
I have a thread here about my first trip this last Sunday w/ pics....
http://www.colorado4x4.org/vbb/showthread.php?t=148993
___Only in an XJ____
XJimmy is offline   Reply With Quote
Old 05-26-2009, 12:52 PM   #8
James750
1990 MJ Comanche
Everything sounds fine with your rig except that you really should get some tow points if you are going to wheel it at all.
1990 mj,
Old 05-26-2009, 12:57 PM   #9
James750
1990 MJ Comanche
Just called the forest service and they said it is open. I am off to get a new tapered sleeve for my track bar and hopefully the problems will be fixed with my rig. Fingers crossed!
1990 mj,
Old 05-26-2009, 01:23 PM   #10
rballman
JK Soccer Mom
rballman's Avatar
I assume you still can't go all the way to the top though?
2007 Wrangler X - Jeep Green, 4" lift, Fab Industries custom front/rear bumpers and fenders, Treks/T&T gas tank skid, 10lb co2 tank, rolling on 35s w/ 15s
Colorado Jeep Club member #2007
My JK Build Thread
rballman is offline   Reply With Quote
Old 05-26-2009, 01:40 PM   #11
XJimmy
A friend of mine gave me a tow hook to attach underneath the front but I dont have the means of getting it on yet... I need a sizable drill bit and the right tool to crank it down once it is on....
This about what I have to attach to the front somewhere:
Old 05-26-2009, 04:37 PM   #12
James750
1990 MJ Comanche
What you need is a set of frame tie in brackets. What they do is attach the tow hook to the 3 bumper bolts and they extend back and tie into the unibody a little bit past the sway bar mount. I would give you my old set, but I gave them away about a week ago to another XJer in need.
Here is what you need:
http://www.jeeperz-creeperz.com/front-hook-p-6752.html
Some companies are selling knock off versions that do not have the unibody tie in portion and are basically just for looks. These will not work for an actual recovery situation. Here is one of them:
http://collinsbros.stores.yahoo.net/xjtowhookbra.html
Without that bar that extends back and ties into the unibody, it will rip out the bumper mounting holes in any real pull.
1990 mj,
Old 05-26-2009, 04:48 PM   #13
James750
1990 MJ Comanche
I asked about conditions and the lady I talked to said that they never closed it this year and nobody has been up it since last fall so I have no I idea what it will be like towards the top. On a good note, I installed the new track bar sleeve and my steering problems are fixed!
1990 mj,
Old 05-26-2009, 07:05 PM   #14
the303hooligan
I may be in on this one too..ill know for sure closer to friday evening.
Colorado Jeep Club Member #'303'
1999 Xj Sport 4.0 w/4.56 Yukons
D30 HP up front & 8.25 out back
33x12.5 BFG T/A KO 15 on soft 8's
True 5" of Lift:3" BDS(springs,coils),2"BDS shackles,2"teraflex spacer,Teraflex LCA,SkyJackr Nitro's shox & Stearing Stabilizer,Teraflex SYE,Spicer Rear drivshaft, TeraFlex Quick Discos,BDS adj. trackbar,JCR Stage4 & Stage2 bumpers,Ohana Fab sliders,Rustys rear 1/4 panel armor,Appalachian Armor T-case skid,ARB Front Diff. cover,JKS LCA Skids,Defender roof rack,6 55w rack lights,60mm bored TB,AC Delco paper air filter,Champion plugs,Grand Cherokee TieRod conversion,Silverstar headlights,HD 3core Radiator,Flowmaster Delta50,Uniden 520pro CB w/PA w/4' Firestick
Originally Posted by LeftOfCenterXJ View Post
Going wheeling without recovery points is like an 18 year old girl at a frat house. You may get away with it a few times, but eventually your gonna be ****ed.
*Give a man a fish and he will eat for a day. Teach him how to fish, and he will sit in a boat and drink beer all day.
the303hooligan is offline   Reply With Quote
Old 05-26-2009, 07:11 PM   #15
James750
1990 MJ Comanche
I have a feeling that we should be able to get pretty far up this trail, if not all the way up. But if we don't make it very far, we can always run Slaughterhouse on our way back. The forest service said that Red Cone and Webster are closed and will likely be closed until at least July 4th.
1990 mj,
red cone sunday the 2nd 307cj7 Colorado Jeep Club 14 08-05-2009 03:52 PM
Red Cone Sunday. jeepster93 Colorado Jeep Club 10 07-13-2009 07:00 AM
Red Cone, Sunday July 27th 10AM Hybrid Jeep Colorado Jeep Club 14 07-28-2008 09:55 AM
Moab Labor Day Weekend- Aug 31st - Sept 3rd REDLYNER Colorado Jeep Club 2 08-02-2007 01:20 PM
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
