Zone 2" lift and 3/4 boomerang shackles - Page 2 - JeepForum.com
post #16 of 28 Old 03-01-2013, 05:20 PM
CBinDC
Photos?
CBinDC is offline
post #17 of 28 Old 03-03-2013, 05:31 AM Thread Starter
lawdawg2524
Did this work or is it still upside down
lawdawg2524 is offline
post #18 of 28 Old 03-03-2013, 05:32 AM Thread Starter
lawdawg2524
After
post #19 of 28 Old 03-03-2013, 05:36 AM
responder
Still upside down!
responder is offline
post #20 of 28 Old 03-03-2013, 07:58 AM Thread Starter
lawdawg2524
Damn I give up, I stick to wrenching on the jeep!
post #21 of 28 Old 03-04-2013, 05:23 AM
NCTinkerer
Sorry to butt in, but maybe I can help with the pics.
93 YJ, $3500.00: What I've done so far - tires; Soft top & frame; turn signal switch; plugs, cap, rotor & wires; new fluids; mirrors; 2 row aluminum radiator, water pump, hoses & thermostat; brake lines and hoses; Transfer case output seal; rear diff crush sleeve and yoke seal; rear wheel cylinders and shoes;
NCTinkerer is offline
post #22 of 28 Old 03-04-2013, 05:25 AM
NCTinkerer
Here is the After pic.
post #23 of 28 Old 03-04-2013, 05:27 AM
NCTinkerer
This is pretty much the result I want on my 93. Did you use the shim for the pinion angle? It looks like maybe you dropped the transfer case.
post #24 of 28 Old 03-04-2013, 06:38 AM
StanF
Looks good - mine is stock, and I will be adding a lift soon.
What size tires are on there now?
StanF is offline
post #25 of 28 Old 03-04-2013, 08:04 AM
Fuddmaster
Thanks for adjusting the pictures!!! I also was thinking about the zone lift over the RC lift. The bds is just out of the budget.
Fuddmaster is offline
post #26 of 28 Old 03-04-2013, 08:41 AM Thread Starter
lawdawg2524
Thanks I just figured it out and was going to try it again when I see you fixed it. yes I shimmed the differential with the shims it came with and I dropped the transfer case. Home made with bolts and oversized nuts as spacers. I did not want to dump a bunch of money into a toy and was going to go with RC but the bad reviews scared me off. I love the zone lift and would do it all over again. I have 235's on and when they wear out I'll probably go with 31's.
post #27 of 28 Old 03-04-2013, 12:28 PM
StanF
The 235s are about 29". The 31s will look great. I'm thinking about squeezing in 32s after I left mine.
The 31s are much more common, and wouldn't require a wheel change, so I may end up with 31s
StanF is offline
post #28 of 28 Old 04-23-2013, 09:36 AM
CBinDC
So how is the ride? What suspension did you have on your Jeep before?
CBinDC is offline
