ZJ axle shafts in a YJ, CAD eliminate - JeepForum.com
post #1 of 16 Old 02-06-2014, 01:31 PM Thread Starter
mnypitZJ
OK so I have a pretty major leak on the passenger side 2 piece axle shaft, and the last time we were out it would not engage for half the trail ride. So after a TON of searching, I decided to use an XJ 1 piece shaft to eliminate the CAD and put the seal in the pumpkin.
My problem came with the fact that every single XJ I find is already missing that axle shaft. Apparently its a popular mod around here.
There are about a dozen ZJs and WJs with the axles intact and u-joints. Will any of them fit? I know mine doesnt have ABS, but it is a 95 so I think it has the larger u-joints. All the ZJs and WJs have ABS.
So which will work? Do I have to get an XJ shaft?
mnypitZJ is offline
post #2 of 16 Old 02-06-2014, 02:10 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
tj and xj are the only 2 I have heard of using
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #3 of 16 Old 02-06-2014, 02:55 PM Thread Starter
mnypitZJ
There are a couple threads here that mention ZJ axles, but its not clear what works and what doesnt.
mnypitZJ is offline
post #4 of 16 Old 02-06-2014, 02:56 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I have heard of using ZJ shafts, but some of them had cv joints. I'm not sure what years are good. If you can go browse the yard to find one with U joints make sure they are the bigger 760s.
Randonexplosion is offline
post #5 of 16 Old 02-06-2014, 02:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just make sure they have the ujoints as mentioned. Early models should have them and its a temporary solution to the problem until you can find a set with bigger ujoints.
Then you'll have a spare set! Keep the unit bearings on them and you'll be ready to roll on the trail and leave the 36mm socket at home.
Luck Favours The Prepared
Anticanman is offline
post #6 of 16 Old 02-06-2014, 03:10 PM Thread Starter
mnypitZJ
I found a 97 in the salvage yard, and started taking out the axle. Of course I didnt have a hammer and I couldnt get the bearing to break loose. But it had a u-joint, just not sure what size. How can I tell that? My understanding is that the 95 YJ has the bigger joints.
The other issue I saw was that it had ABS, so it has the ABS gear on it. Does this matter?
mnypitZJ is offline
post #7 of 16 Old 02-06-2014, 03:15 PM
Randonexplosion
Deplorable
Pretty sure you can just knock the ABS tone ring off. The smaller joint (260) has a cap diameter of 1.0620" and the larger (297/760x) is 1.1880".
post #8 of 16 Old 02-06-2014, 03:41 PM Thread Starter
mnypitZJ
OK so probably no way to tell while laying in the mud at the salvage yard. Crap. I would like to believe that since its a Grand Cherokee that it has the larger units like a Cherokee?
mnypitZJ is offline
post #9 of 16 Old 02-06-2014, 03:44 PM
Mark05059
not always. They had the smaller joints on the zj's as well.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #10 of 16 Old 02-06-2014, 03:49 PM Thread Starter
mnypitZJ
That is just weird that Jeep would make every single XJ after 95 the larger one, but not the higher end ZJ? I am not questioning you, it just baffles me as to why Jeep did this. I dont do a lot of serious wheeling right now in this, so the smaller joint may be fine for a while.
mnypitZJ is offline
post #11 of 16 Old 02-06-2014, 04:15 PM
Randonexplosion
Deplorable
FWIW im still rocking stock shafts with cad fork locked over on 35s with a V8 and I havent broken a shaft.... yet.
post #12 of 16 Old 02-06-2014, 04:21 PM Thread Starter
mnypitZJ
I would do that, but I have to remove the shaft anyway to do the seal, I need a wheel bearing in my ZJ, and the shaft is only $15 with a bearing, so I figured I would do it.
mnypitZJ is offline
post #13 of 16 Old 02-06-2014, 08:28 PM
90DesertTanYJ
You could ask which models have the bigger u joints over on the XJ, ZJ, WJ forum here. Not knowing but maybe it would stand to reason the bigger u joints may be on V8 Grands rather than the I6's? I dunno thats just a guess. How are expensive are new XJ or TJ axles? That might be an option if they arent to pricey.
90DesertTanYJ is offline
post #14 of 16 Old 02-06-2014, 08:31 PM Thread Starter
mnypitZJ
OK found a TJ axle shaft so I am going to go with that. I know it will fit.
mnypitZJ is offline
post #15 of 16 Old 02-06-2014, 08:51 PM Thread Starter
mnypitZJ
The ones I have found new have been over $200 and I am not sure they come with u-joints and the outer knuckle part. I figured for $15 I would do it, but I dont need to do it at all. But now I have a TJ shaft, and it was only a bit more money, so I am good. I wonder why nobody uses the ZJ units?
mnypitZJ is offline
