you know you drive a YJ when..... - Page 779 - JeepForum.com
 118Likes
post #11671 of 13867 Old 03-18-2013, 06:54 PM
konadubrock
YKYJAYJW your girlfriend complains all the time about driving her p.o.s. exploder and wants a jeep. Then says she is afraid to get one because you spend too much time fixing it.
konadubrock is offline
post #11672 of 13867 Old 03-18-2013, 07:02 PM
rawlston
Get her a jeep and put the exploder axles under yours. Its a win win
Just
Empty
Every
Pocket
"Guns kill people like spoons make Rosie O'Donnell fat."
rawlston is offline
post #11673 of 13867 Old 03-19-2013, 07:22 AM
BretB
YKYJAYJW after approximately morning #33 of not driving it it won't start for work (and the tranny's out on your truck), then you come home that night, hop in, and she fires right up. Moisture
1989 YJ
1998 Harley Davidson Fatboy
2000 TJ (wife's)
2009 Chevy K1500
BretB is offline
post #11674 of 13867 Old 03-19-2013, 08:28 AM
8pitcher
8pitcher's Avatar
When it is in better shape than your Jk.
8pitcher is offline
post #11675 of 13867 Old 03-19-2013, 08:41 AM
act3k
When you use rhino lining for entry guards rather than buying a set
act3k is offline
post #11676 of 13867 Old 03-19-2013, 09:04 AM
sdoherty
When you are driving down the road trying to remember if you put everything back together or not..
sdoherty is offline
post #11677 of 13867 Old 03-19-2013, 09:40 AM
jimmyjamster
It's only a critical part if it takes more than 2 bolts.
jimmyjamster is offline
post #11678 of 13867 Old 03-19-2013, 02:26 PM
skorp1702
And every other spot that rattle doesnt last long on
skorp1702 is offline
post #11679 of 13867 Old 03-19-2013, 02:27 PM
skorp1702
Wd-40 in the distributor cap works everytime
post #11680 of 13867 Old 03-19-2013, 09:51 PM
Ileea
YKYDAYJW you are planning a tattoo of the Jeep grill and headlights emblem w square headlights.
Ileea is offline
post #11681 of 13867 Old 03-20-2013, 07:02 AM
BretB
Thanks for the tip!
1989 YJ
2000 TJ (wife's)
2009 Chevy K1500
BretB is offline
post #11682 of 13867 Old 03-20-2013, 07:21 AM
skorp1702
Thanks for the tip!
No prob i give mine a sqirt in the vent about every 3-4 months depending on how much rain we get
post #11683 of 13867 Old 03-20-2013, 05:54 PM
rambo3489
When you don't even have to check your tag when you put your shirt on. You can tell what side is the back because of the amount of dirt on it from lying on the floor so much
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #11684 of 13867 Old 03-20-2013, 08:30 PM
Forge04
Originally Posted by yjrock88
when you've never spent less than double what you thought you were going to spend on your project
+1
Forge04 is offline
post #11685 of 13867 Old 03-20-2013, 10:36 PM
stuckparatroope
YKYDAYJ....when..the wife asks...didn't you get that fixed!?...and you can honestly say, that was just the smaller part of the problem...but its almost done I promise!
"If a trail breaks your jeep....this is a formal insult, grounds for retaliation from the jeep gods in the form of a motor swap, bigger lift kit, bigger tires, and a grudge run at it....break out your cameras boys...and, WATCH THIS!!!!" - last words before the demise of my favorite jeep!
stuckparatroope is offline
Can I remove the front drive shaft and still drive around? CobraKhan TJ Wrangler Technical Forum 58 11-12-2014 04:28 PM
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 02:11 PM
POLL: Ok to Drive w/ rear drive shaft? Libtekguy TJ Wrangler Technical Forum 14 07-02-2008 11:25 AM
