you know you drive a YJ when..... - Page 504 - JeepForum.com
 86Likes
post #7546 of 13841 Old 09-23-2011, 11:17 AM
Ripper3494
Originally Posted by nathanninja
If only I had that much money to put into the Jeep, I've also only had it since March. There's probably another $500-1000 in random trips for random parts
You know you drive a YJ when it's not "irresponsible and disrespectful of your money" to leave the YJ out in the rain without the windows in. She likes it! Plus as long as its not windy the rain doesn't barely get in
Only reason its that much is because I've made a lot of mistakes and bought a lot ofsupposibly working parts...
Sent from my DroidX because I should be doing something else
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #7547 of 13841 Old 09-23-2011, 11:42 AM
ninjakid
1987 YJ Wrangler
Does equipment and tooling count?
Lesse jeep was 2300.
Brand new weber 32/36 carb with everything needed and instructions printed out from jeepforums in the box from eBay for 200.
450 for 30 over 258 rebuild kit.
275 for rebuilt tf999 and then I'm gonna rebuild the other one, relocate the vent and do something with it.
90 for a np231 from eBay that is missing the tag off it and I know nothing about it.
258 dollars to get the crank ground (a tad pricy but they were the best shop around and had a real crank polisher and I find the price amusing.)
350 for a kwik way boring bar which was cheap since they go for over 2000 and just finished boring my cylinders with it.
Another 100 for a bunch of other tools, hone, micrometers, and a lot of other stuff.
60 for a bikini top.
150 for a pair of half doors which I need some yj latches for.
And a couple other things I'm missing plus a thousand tiny parts
20 for a 98 4.0 head off craigslist that is just sitting there
200 for valves and related equipment.
Someone add that up for me.
And you know you own a carbed yj when your moms Cherokee has a bad head gasket and you drag it to work to change it and you hardly get anywhere since there are a couple thousand wires going everywhere that are getting in your way, you can't even pull the valve cover off without removing a bunch if stuff off it and it took you forever to find the radiator drain since it has something related to this system called A/C (what's that?) on the front of it and getting in your way.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #7548 of 13841 Old 09-23-2011, 11:46 AM
Firefyter-Emt
You know you drive a YJ when you have to stop and ponder the year of every component while at the part store in order to ensure you are buying the correct part. (Hey, my Jeep spans 15 years of parts!)
Firefyter-Emt is offline
post #7549 of 13841 Old 09-24-2011, 08:31 AM
JeepDrew_94
You know you drive a YJ, when after a monsoon rain storm there is a puddle in the drivers side floor board from the doors not sealing all the way.
Its been raining just about everyday here this week.
JeepDrew_94 is offline
post #7550 of 13841 Old 09-24-2011, 03:20 PM
90yjblkyellow
you know you drive a yj ,when a smart car rides your a** on the highway for two miles and when it finaly passes you its a old lady giving you a look like your clogging her lane
90yjblkyellow is offline
post #7551 of 13841 Old 09-24-2011, 03:40 PM
90yjblkyellow
Originally Posted by Yeepin View Post
i vote this thread best yj thread of all time..
you know you drive a yj when
you read this entire thread laughing and grinning the whole time because everything is so true.. And the old lady looks at you like your crazy.
then you go to work in the morning look down at passengers floor and see a 5qt jug of oil a gallon off anti freeze mix and a jug of window cleaner and start laughing all alone again
post #7552 of 13841 Old 09-24-2011, 03:55 PM
90yjblkyellow
you owned a rusted half broken rotted frame 87 four cyl and upgraded to a 90 cause off 6 cyl power steering and no rot and i missed the ride
post #7553 of 13841 Old 09-24-2011, 04:14 PM
Firefyter-Emt
Originally Posted by 90yjblkyellow View Post
you know you drive a yj ,when a smart car rides your a** on the highway for two miles and when it finally passes you its a old lady giving you a look like your clogging her lane
Yea, I just drive slower on them, and down shift to a stop. Brakes only need to to be used for a second or two at a final stop.
post #7554 of 13841 Old 09-24-2011, 07:10 PM
AmmitOsiris
AmmitOsiris's Avatar
You know you drive a yj when its all stock and you're bottoming out everytime you go over a speed bump.
Or when it wheels better stock than a blazer or bronco
AmmitOsiris is offline
post #7555 of 13841 Old 09-24-2011, 08:41 PM
Reddy89
when you literally have to inch over the speed bump as to not render your rear passenger unconscious.
Reddy89 is offline
post #7556 of 13841 Old 09-24-2011, 08:55 PM
Ripper3494
Actually I go faster for that reason, my friend that sits back there is a ginger lol
build thread:
RC vs BDS
post #7557 of 13841 Old 09-25-2011, 08:00 AM
jeepmom5
so true...
also you know you drive a yj when....
a good rain storm gives you the chance to wipe your jeep clean with just a rag....no fancy car washes or anything
jeepmom5 is offline
post #7558 of 13841 Old 09-25-2011, 08:07 AM
RockOn93
RockOn93 is offline
post #7559 of 13841 Old 09-25-2011, 06:39 PM
AmmitOsiris
Yeah well my only passenger in the back is my black lab she's a tard or when I'm goin to school its my backpack I'm in hs but yeah npt o many fit back there
post #7560 of 13841 Old 09-25-2011, 08:19 PM
Wrangler2012
x2 on the highschool jeeper!
Wrangler2012 is offline
Can I remove the front drive shaft and still drive around? CobraKhan TJ Wrangler Technical Forum 58 11-12-2014 05:28 PM
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 09:39 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 11:58 PM
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 03:11 PM
POLL: Ok to Drive w/ rear drive shaft? Libtekguy TJ Wrangler Technical Forum 14 07-02-2008 12:25 PM
