Quantcast York OBA project - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > York OBA project
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 03-01-2008, 03:44 PM   #61
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
Originally Posted by nic99007 View Post
I found these "filters" http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?ItemId=1611626466 being talked about on another forum. Do y'all think they would work? They would be really easy to put on
pretty much any filter will work. you're just venting the case so pressure doesn't build up so it just needs to a) filter any incoming air so you don't contaminate the oil with dust, etc and b) act as a baffle to keep the oil from coming out with the air. those filters are using NPT threads so you'll still have to adapt them to the plug threads. also, grainger doesn't sell to the public last i knew, you have to be a business. you can always try McMaster-Carr or MSC supply though once you know the grainger part number.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote
Old 03-01-2008, 04:44 PM   #62
nic99007
I work for a car lot, so i'll just use the business to get the part and see how it works. for $4 i can't be to upset if it won't work. and if anyone else wants one I could order more once i see how it works
nic99007 is offline   Reply With Quote
Old 03-05-2008, 02:31 PM   #63
nic99007
So, I recieved the filter from Grainger today. It looks like it will work great. I could have gotten the next smaller sizea and been fine, Oh well. Now my dilema is where to find an adapter to go from the York case to the filter. According to the York manual the oil plug threads are 3/8" - 24 UNF and the threads on the filter are 3/8" NPT. Any one have suggestions of where to find such an adapter?
PS If anyone else wants these filters I can get them. Shipping was $4.89 for the $3.19 part, go figure
Old 03-05-2008, 07:14 PM   #64
sentinal02
sentinal02's Avatar
go back a few posts, i covered adapting the threads. you can get the -3 AN fitting to adapt to a couple different sizes of NPT's so you should be able to adapt to the 3/8 size. if not directly, then just grab a reducing bushing once you get to the NPT size.
Old 03-05-2008, 07:34 PM   #65
Tomb Raider
MyJKRocks!
I received my check valve and coelesant filter in the mail a few days ago. I'll let you know how they work when I put them on. I'm waiting on ARB parts as well...so I'll check it all at the same time.
Tomb Raider is offline   Reply With Quote
Old 03-05-2008, 08:12 PM   #66
will_982
Thought I'd throw pics of what mine looks like, I did put the coelesant filter and check valve in, still haven't mounted the tank yet, hard to make time to play. The small line feeds up to a gauge mounted in the dash.
will_982 is offline   Reply With Quote
Old 03-06-2008, 09:54 AM   #67
Jeepfreak81
Here is my setup, have to finish the tank mount, and paint it. Other then that it is done. I just re-plumbed it with brake line because I was blowing out hoses. (Cheap hose) and the brake line looks more finished. Mine is the medium sized York (freebie) 8 CFM IIRC.
I started with the tank on the fender under the hood, didn't like it - cramped the engine bay. Then I moved it underneath and didn't like that either for safety reasons -- worried about punctures at high pressure. So to the rear wheel well it went.
Need to finish mounting the lines to the frame permanently, and put on the intake filter, might try to find a way to vent the case like mentioned above.
I HIGHLY recommend making the plugs for the QD's as they like to get packed with road grime, sand and mud.
here are some vids before I replumbed it... (pressure switch is jumped to the battery, toggle switch isn't hooked up yet) this is very impressive, keeps up with my air chisel AND my Impact, if I bumped it up off idle I am sure the VERY minimal drop off I see would go away. -- keep in mind this is the MEDIUM sized York -- 8CFM IIRC
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife)
1946 CJ2A, 225 V6. mild lift - TIME TESTED
1966 M416 1/4 ton Military Trailer -- WAR TESTED
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline   Reply With Quote
Old 03-06-2008, 10:00 PM   #68
cooltc2004
Where would you purchase the clutch/pulley set from ?
http://www.fquick.com/cooltc2004
1988 Jeep Wrangler YJ
cooltc2004 is offline   Reply With Quote
Old 04-03-2008, 02:43 PM   #69
nic99007
OK
I finally got the little filter put into the crank case. At the same time i added a coalesing (sp) filter that has a little sight window. last time i used my air pre filter is was getting a shower from all the oil spraying out. now with the filter in the crank case I dont even get any oil in the coalesing filter. It's great. So, moral of the story is, if you don't want oil everywhere, vent your crank case. and the coalesing filter couldn't hurt either.
Old 04-03-2008, 04:26 PM   #70
nic99007
Here's a picture of the filter all installed.
Old 04-03-2008, 06:32 PM   #71
YJames90
aka Jamesx2
YJames90's Avatar
Heres a few pics of mine
The parts
[IMG][/IMG]
The tank mounted
[IMG][/IMG]
The guage and power switch
[IMG][/IMG]
The works
[IMG][/IMG]
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/
If your going to talk about me talk to me
YJames90 is offline   Reply With Quote
Old 04-03-2008, 08:03 PM   #72
theBridge
Originally Posted by Tomb Raider View Post
That donor list says that cherokees made from 83-76 have yorks which doesn't make sense, I thought the xj started in '84. Does anybody what year they put them in the xj's, if at all? I'm checking out an xj tomorrow that someone is parting out.
theBridge is offline   Reply With Quote
Old 04-03-2008, 08:19 PM   #73
Tomb Raider
MyJKRocks!
A full size cherokee and an XJ are not the same animal.
Old 04-03-2008, 08:23 PM   #74
theBridge
Ahh makes sense now
Old 04-17-2008, 08:56 AM   #75
j33pman
I didn't see this anywheres. What did you and up using for an adapter for the filter. I was thinking about using a die to turn
down an 1/8" NPT Street elbow and mounting my filter to that.
Bill H. - 1984 CJ-7
258 W/ Weber DGV 32-36, T5, Twin Stick Dana 300, Custom SOA,
Dana 30/AMC 20 Locked 4.56's, 33" Swamper LTB's, York OBA,
Custom bumpers, Homemade Swaybar Disconnects, Nutter Bypass, Team Rush
http://www.schohariecountyjeepclub.com
j33pman is offline   Reply With Quote
Glock Forum
