#1 | |
MyJKRocks!
York OBA project
Well....
Yet another project I've wanted to do for awhile but never got around to starting. On Board Air. In moab, I watched the one guy with OBA air up 4 rig's tires with out so much as a wimper. He ran an air die grinder with great results. All off a York 210 air compressor setup. I've had this york setting here for going on a year now. It's the 210 model, which is the largest volume york made. At 1500rpm's, it can outperform most home air compressors with it's CFM output. So......another project begins. I started with a york off a 75 scout II that I had. I bought the scout for $200, sold the axles for $250 and got the york off it...basically for nothing. "Free" is always good in my book. ![]() Now, as you can see.....it came with a double V-belt clutch on it. No good for me, since I have a serpentine setup. With jeeps, only the 258 engine had a vbelt setup. All other's were serpentine setups....so keep that in mind if your gonna go this route. Since I needed a serpentine setup, I did a little research and poking around online and found a serpentine clutch that will work with the 210 model york's. Bingo...I was in business. $65 bucks to my door. You can find it ![]() ![]() The other "large" piece to this setup is a tank. While the york can put out a decent amount of air on it's own.....once you add a tank to an OBA setup, your options open waaayyy up. Virtually any air tool, and less cycling of the compressor. All add's up to quick tire inflations and easy work of air tasks. Again, ebay to the rescue. I found the VIAIR 2.5 gallon tank on there for 55 bucks shipped to my door. Not bad I didn't think. The up side's to this tank. 150psi working pressure. SIX ports. Yes....six. More than I'll ever need for a great setup, and room for expansion if I need it. The tank has feet with rubber isolators to mount it securely to the bottom of the jeep. ![]() So this is where I begin the project. My plan is to go hunting this weekend for all the fittings/regulator/pressure valves...etc. and hopefully get everything I need to get it going. If time permit's, I'll start on the install this weekend. My plan is really no different than most OBA setups, front and rear ports, regulators at both ends so I can attach air tools both in front and rear, and plumb the tank to the underside of the rig....drivers side just inside the frame rail. More pic's as they come!!! -Scott
2007 JK Unlimited Sahara 37" Irok ND's 4" rough country lift |
#2 |
Looking forward to seeing how this project goes
'95 Wrangler 2.5L Rear Aussie 31X10.5X15 Hitech AT's 2.5" Rubicon Express SD Lift Midland CB w/ 4' Firestik II |
#3 |
Me too. I want to do this to my pickup.
Edit: I just realized we have the same accessory system now that you have a 350. How are you mounting it to the GM serpentine brackets? |
#4 |
MyJKRocks!
Going to attempt to build one of these:
![]() If I have no success, I'll buy it. If I do have some luck at it chris....I'll fab up two. Should look like this: ![]()
#5 |
I don't need one I have C02 on the YJ. Just wondering what you had planned.
Thanks anyway! |
#6 | |
MyJKRocks!
I just figured you had a 350 in your truck as well.
#7 |
Nope. Not a V8 in my truck
#8 |
This should make for an interesting add on. Can't wait to see how you do it. Take pics and keep us posted!
#9 |
Yeah, It's A Jeep Thing!!
I am subscribed!!!
Keep the pics coming as you make progress. Good score on the Scout too Scott!!!! Todd
2007 JK Unlimited "X"
TeraFlex 3" Kit with 4 Arm Flex Kit, TeraFlex HD F & R Adj. Track Bar, Rock Krawler Spring Levelers, Yukon 5.13 Gears, Black Rock Soft 8 Steel Wheels 16x8 (4.25" BS), Cooper Discoverer STT 315/75/16, XRC Rear Bumper w/Tire Swing, Rugged Ridge Front w/Stinger, AEV Snorkel, Cobra 75, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fender Flares |
#10 | |
Jello Puddin'
Tomb,
Any idea what had the York 210 in them (other than the Scout), for salvage hunting???
#11 |
You're going to love your York. Besides the capacity, it's a much better long term solution IMO. My dad put a used York on his about 25 years ago and it keeps on going. I just don't see the electric pumps lasting that long. Dirt is eventually going to get into them and being unlubricated I just can't imagine them lasting.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards... |
#12 | |
I'm pretty sure that the 83 volvos had them in it some wagoneers i think did as well.
1993 Jeep Wrangler 4.0L Tom Woods rear HD shaft D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,5" BDS, homemade greasable boomerang shackles, SS braided lines, rubicon flares, 1" prothane body lift, 35" TrXus M/T, smitty built XRC, armor and a paint job soon to come. |
#13 |
Good deal on the clutch
Maybe I'll get around to starting my setup and follow along. Dimensions on the tank ? Do you plan on rebuilding the york ?
'94 4.0 auto, Rubicon Express 4", 32x11.5 BFG AT, Herc'd, other stuff..... |
#14 | |
By These Things I Stand !
Scott, comming with the cool projects again. Keep up the good work.
White Jeep Club Member #1488 "Sometimes, there's Justice.......Sometimes, there's Just Us. " - Living my life on a Thin Blue Line - Quote:
#15 |
Just to add to this thread. If hunting one down in a salvage yard bring a 6v lantern battery and apply it to the York. You should here the clutch kick in and then put a finger on the outlet and give it a full turn and a half. Remove finger and you should have preasure. Make sure the York does a full turn.
zman
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
