Yoke on XJ - JeepForum.com
post #1 of 2 Old 02-13-2013, 01:27 AM Thread Starter
Drew_CarreyAB
Yoke on XJ
I was wondering if the front axle yoke on an XJ D30 could be swapped out or onto a YJ front axle? The reason I ask is that I'd like to replace the front driveshaft with the cardan style. I already have the yoke to replace on the transfer case, but can I use the strap style already in place on the axle? The front DS splines are worn to the point of rubbing the exhaust. And the angle is very severe.
My plan is to replace the front DS, do the SYE, and drive for the day or two on the front axle while the rear DS is being built, keeping the D35 till the 8.8 swap and do the rear shaft again. Or should I wait until I have a pile of parts, then do it all at once?
Doesn't matter what year, as long as you have square headlights :) - Pyrate 7
Arguing on the internet is like winning a race in the special olympics. Even if you win, you are still retarded.
Pain is the payment for each precious step..........
Last edited by Drew_CarreyAB; 02-13-2013 at 01:49 AM. Reason: iPhone was plugged into unreliable power source, making typing jittery.
Drew_CarreyAB is offline
post #2 of 2 Old 02-13-2013, 06:30 AM
SeanB95YJ
would save you time and money in the long run to wait until you've got the 8.8 ready, THEN do the rear DS
as far as I know, the YJs front pinion yoke should be fine as long as it's not damaged
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
